View Full Version : Bizhub C284 Service mode
MFPTech
06-02-2014, 06:37 PM
Hi,
This might sound like a stupid question but when I go to Menu - Counter there is no KeyPad tab below or above the Meter Count.
Any ideas how to call the service mode please?
Thanks in advance!
xscotty1990
06-02-2014, 07:32 PM
Hi,
if you got a c284 just push the Display over to the left side then you will see the keypad:D:D
Greetings
Marco
stevena86
06-02-2014, 08:32 PM
Hi,
Greetings
Marco
This or if it is an e series, top left corner there is a soft key labeled 'Display Keypad' and bam there you go.
MFPTech
06-02-2014, 11:10 PM
Hi,
Greetings
Marco
Thank you for your help and for saving my the embarrassment!
However, not sure if I am the stupid one or Konica for coming up with such an inconsistent design.
blackcat4866
06-03-2014, 12:52 AM
When going through the keystrokes to enter service mode, go slowly, like 2 seconds between each keystroke. If you don't hear the beep with each keystroke it won't work. I'm thinking of the e-series. =^..^=
stevena86
06-03-2014, 02:24 AM
We turn the sounds off at my work. You can do it without the beep. I just go at a steady pace. Too little or too much time between the keystrokes causes it to not work.
What was wrong with hard keys anyway? :(
xscotty1990
06-03-2014, 09:00 AM
I have been on training for bizhubc454e for a while.
They said that the machine recogneizes the touch on the
touchpad but just doesnt beep. There must be a soundlag or something.
Just switch off the keypadsound and everything is fine.
Greets
Marco
rrrohan
06-03-2014, 01:29 PM
Physical keypad is a option now. Funny how things like duplex and dual scan that use to be optional extra are now standard but keypad that's been around for years as standard is now the option
