Bizhub 350 Touch Screen Not Responding - Scan function
  • vogmusic
    • Jul 2025
    Hello,
    I'm new here, thanks for all your useful comments in the forum.
    I recently got a used Bizhub 350, worked fine so far. 3 days ago, the touch panel didn't respond, I restarted the machine and went back to life. Yesterday, same thing happened, but after several times restarting yesterday and today, it doesn't work. Yesterday morning, I cleaned the panel with a slightly wet cloth, I'm not sure if that's what happened or it's just mere coincidence. I appreciate your help.
    Also, is there any way to scan from a Mac?
    Thanks for all your comments!
  • Splatt
    • Dec 2012
    • 32
    Re: Bizhub 350 Touch Screen Not Responding - Scan function
    First off, I'm not a tech, just an optimistic end user.
    The problem can be caused by a bit of crud somewhere causing an 'always on' situation. Try running a business card around the bezel to dislodge or remove anything that might be there. Failing that, if you can remove the panel and give it a clean that might do the trick.
    I'm not familiar with the 350, but my 6500 also has a USB at the rear of the unit, which, when you insert a USB mouse causes a pointer to magically appear! Got me out of trouble a couple of times.
    If you are using a Fiery and command workstation it comes with an application for remote scan.
    Hope this helps, until someone more knowledgeable comes along!
    Steve.
    • Hansoon
      • Sep 2007
      • 3383
      Let a tech replace the touch panel. No other way around it. The touch panel deteriorates with time and must be replaced.
      Hans
      • vogmusic
        Steve.
        Thanks Steve! It worked! I used a very thin plastic instead, a lot of things came out. This unit doesn't have USB that I'm aware of. Let's see how long it lasts.
        Thanks for the scanning info, researching now
        Hans
        Thanks Hans, I know it's an old unit and I'll have to replace parts sooner or later...
