20gaugeO/U
07-21-2014, 07:55 PM
We are looking to unload some common Panasonic 35/45/60 CPM PM parts and some oddities that have accumulated over the years.
PM me with anything that interests you and we can work out something. The more the better.
Thanks for looking, JL
PART #
DESCRIPTION
MODEL(S)
QTY
DZTE000044R
TOUCH PANEL
8060/8035 & 3030/8032
4
3041
LFR Generic OEM#= DZLA000266
8060/8045
1
3110
LFR Generic OEM# = DZHP007236
6030
1
3182
UFR Generic OEM#= DZLA000286
8035 3530 ONLY
1
B3NZA0000020
FUSER EXIT SENSOR
6030 / 8060
2
DQ-H360R
DRUM
8060/8045/8035
1
DQ-Z240R
DEV
8060/8045/8035
3
DZAL000216
REG SENSOR
6030 / 8060
4
DZBL000045
THERMISTOR
3530/8035
2
DZBL000046
THERMISTOR FRONT
6030 / 8060
2
DZDX000013
THERMAL FUSE
3530/4530/6030
1
DZDX000017
THERMOSTAT
3530/4530/6030
2
DZEC103748
PC SYSTEM CONSOLE
8060 / 8045 / 8035
1
DZGA000010
DUPLEX XPORT ADU CLUTCH
8060 / 6030
1
DZGA000020
REG CLUTCH
8060 / 8045 / 8035
2
DZGA000022
DUPLEX CLUTCH
8060 / 8045 / 8035
2
DZGA000028
REG CLUTCH
8060 / 6030
1
DZGA000029
REG CLUTCH
8060 / 6030
3
DZHA000163
CORONA COVER
80/60
4
DZHA000164
CORONA COVER
6030 / 8060
2
DZHP007146
DRUM SEAL (FRONT)
6030 / 8060
2
DZHP007147
DRUM SEAL (REAR)
6030 / 8060
2
DZHP007236
PRESSURE ROLLER
3530/4530/6030
2
DZJB000411
REAR CORONA BASE
6030/8060
4
DZJB000470
TONER SUPPORT MYLAR
6030/8060
3
DZJB000478
FRONT CORONA BASE
6030/8060
3
DZJE000937
CLEAN COVER
6030
1
DZJF000519
CORONA GUIDE COVER
80/60
2
DZJL000210
CORONA GRID
3530/4530/6030
5
DZJM000727
FUSER LEVER
80/60
3
DZJM000803
SEAL SPONGE
6030
1
DZJM000812
DEV SEAL
6030
1
DZJM000817
SEAL SPONGE
6030
1
DZJM000818
SEAL SPONGE
6030
2
DZJM000960
DEV SEAL
6030
1
DZJM001353
SEAL SPONGE
6030
2
DZJP000050
DEV SEAL
6030
1
DZLA000266
HOT ROLLER
3530/4530/6030
1
DZMA003404
DEV COVER LOWER
6030
1
FFPLP0743
FUSER SPRING
6030/8060
13
FFPMQ0383C
BUSHING
6030 / 8060
3
FFPXA65H001
FUSING KNOB
6030 / 8060
1
FFPXL04H00
TRANSFER CORONA
80/60
5
FFPXL05H00
CHARGE/SEP CORONA
80/60
5
GH03-2127
Metal Wire Finisher
FS-330
1
K0BDB0000079
THERMOSTAT
6030 / 8060
7
K5X184BH0001
THERMAL FUSE
3530 / 8035 ONLY
3
L9AAAEFZ001
FUSER WEB SOLENOID
6030 / 8060
5
L9EAAJ000028
ADF REG CLUTCH 2
6030/8060/COLOR
2
L9EAAK000008
REG CLUTCH
8060 / 6030
1
L9EAAK000012
CLUTCH
8060 / 6030
1
PJBEC0013Z
DISCHARGE CORONA
3530/4530/6030
6
PJDGC0195Z
FUSING WEB 1-WAY GEAR
6030 / 8060
4
PJHRC0347Z
FUSER FINGERS
8060/6030
5
PJZYF2754-PU
DRUM BLADE
8060
2
PJZYF3158PU
CORONA CLEANING PAD ASSY
80/60
3
*** DQ-M35R24-PU
240K PM KIT INCLUDES THE FOLLOWING
8060
1
TRANSFER CORONA
TRANSFER SEP CORONA
DISCHARGE CORONA
TONER WASTE CONTAINER
OZONE FILTER 1 & 2
DUST FILTER
V OZONE FILTER 6
CLEANING PAD ASSEMBLY
CLEANING FELT FRONT AND REAR
CLEANING BLADE
INSULATION BUSHINGS
NO FUSING WEB IN KIT
PART #
DESCRIPTION
MODEL(S)
QTY
DZTE000044R
TOUCH PANEL
4
3041
8060/8045
1
3110
6030
1
3182
8035 3530 ONLY
1
B3NZA0000020
FUSER EXIT SENSOR
6030 / 8060
2
DQ-H360R
DRUM
8060/8045/8035
1
DQ-Z240R
DEV
8060/8045/8035
3
DZAL000216
REG SENSOR
6030 / 8060
4
DZBL000045
THERMISTOR
3530/8035
2
DZBL000046
THERMISTOR FRONT
6030 / 8060
2
DZDX000013
THERMAL FUSE
3530/4530/6030
1
DZDX000017
THERMOSTAT
3530/4530/6030
2
DZEC103748
PC SYSTEM CONSOLE
8060 / 8045 / 8035
1
DZGA000010
8060 / 6030
1
DZGA000020
REG CLUTCH
8060 / 8045 / 8035
2
DZGA000022
DUPLEX CLUTCH
8060 / 8045 / 8035
2
DZGA000028
REG CLUTCH
8060 / 6030
1
DZGA000029
REG CLUTCH
8060 / 6030
3
DZHA000163
CORONA COVER
80/60
4
DZHA000164
CORONA COVER
6030 / 8060
2
DZHP007146
DRUM SEAL (FRONT)
6030 / 8060
2
DZHP007147
DRUM SEAL (REAR)
6030 / 8060
2
DZHP007236
PRESSURE ROLLER
3530/4530/6030
2
DZJB000411
REAR CORONA BASE
6030/8060
4
DZJB000470
TONER SUPPORT MYLAR
6030/8060
3
DZJB000478
FRONT CORONA BASE
6030/8060
3
DZJE000937
CLEAN COVER
6030
1
DZJF000519
CORONA GUIDE COVER
80/60
2
DZJL000210
CORONA GRID
3530/4530/6030
5
DZJM000727
FUSER LEVER
80/60
3
DZJM000803
SEAL SPONGE
6030
1
DZJM000812
DEV SEAL
6030
1
DZJM000817
SEAL SPONGE
6030
1
DZJM000818
SEAL SPONGE
6030
2
DZJM000960
DEV SEAL
6030
1
DZJM001353
SEAL SPONGE
6030
2
DZJP000050
DEV SEAL
6030
1
DZLA000266
HOT ROLLER
3530/4530/6030
1
DZMA003404
DEV COVER LOWER
6030
1
FFPLP0743
FUSER SPRING
6030/8060
13
FFPMQ0383C
BUSHING
6030 / 8060
3
FFPXA65H001
FUSING KNOB
6030 / 8060
1
FFPXL04H00
TRANSFER CORONA
80/60
5
FFPXL05H00
CHARGE/SEP CORONA
80/60
5
GH03-2127
Metal Wire Finisher
FS-330
1
K0BDB0000079
THERMOSTAT
6030 / 8060
7
K5X184BH0001
THERMAL FUSE
3530 / 8035 ONLY
3
L9AAAEFZ001
FUSER WEB SOLENOID
6030 / 8060
5
L9EAAJ000028
ADF REG CLUTCH 2
6030/8060/COLOR
2
L9EAAK000008
REG CLUTCH
8060 / 6030
1
L9EAAK000012
CLUTCH
8060 / 6030
1
PJBEC0013Z
DISCHARGE CORONA
3530/4530/6030
6
PJDGC0195Z
6030 / 8060
4
PJHRC0347Z
FUSER FINGERS
8060/6030
5
PJZYF2754-PU
DRUM BLADE
8060
2
PJZYF3158PU
80/60
3
*** DQ-M35R24-PU
8060
1
TRANSFER CORONA
TRANSFER SEP CORONA
DISCHARGE CORONA
OZONE FILTER 1 & 2
DUST FILTER
V OZONE FILTER 6
CLEANING BLADE
INSULATION BUSHINGS
