radu
07-28-2014, 05:47 PM
Hi guys,
I've been working on this machine for a while now - and I managed to get it running at full potential, with some copy quality problems.
The firmware on it is: GC3-72 and when I do color copies only I get vertical color lines equally spread on the sheet every 7/16 of an inch.
If I select single color cyan - the output comes with magenta stripes, the copy quality is beautiful - if you like stripes :).
Same if you want single color magenta - you get cyan stripes. - for yellow you get magenta stripes.
Print quality is perfect and no stripes - so the problem will be at the scanner section.
I'll dig into this problem myself - but if any of you have seen this before please do enlighten me.
Thank you guys,
Radu
Thank you guys,
Radu
