View Full Version : Error Code license management error
nezzy2120
08-03-2014, 06:53 PM
I have a C550 I had to do a nv ram reset. After that I got the message License management error.How can I fix this with out calling Konica minolta
blackcat4866
08-03-2014, 07:10 PM
Somehow, I get the feeling you don't actually read the responses to your posts:
http://www.copytechnet.com/forums/rants-raves-and-everything-else/90647-license-manager-error.html#post427875
Just because you don't like the answer, doesn't mean that it isn't the answer. Asking three times will not change the answer.
Call a KM dealer. That's it. The end. =^..^=
copier addict
08-03-2014, 10:49 PM
I'm not sure if this will help you with your C550, but I have had License management errors on three C353 series machines and replacing the EEProm has fixed it all three times. I didn't have to call KonMin once.
Hope this helps
Hope this helps
But the problem is where to get new EEPROM ? get from form KM ? what different call KM ? :)
CopyJunkie
08-04-2014, 07:52 PM
I had a Bizhub 601 come up with a license management error after wiping the HDD. A technician can use the License Management Server to request a initialization code which should reset it.
