View Full Version : Display panel adjustment setting not showing. - c454e
Hi Everyone
Got this bizhub c454e, I was gping to adjust the touch panel but the panel adjustment setting in the Accessibility section is not showing. I upgraded firmware but still the same. Is there a software switch I need to turn on for the setting to display. Any ideas that may help solve my issue.
Thanks.
Nelo
RRodgers
08-15-2014, 02:44 PM
Hi Everyone
Thanks.
Nelo
Same machine that won't do gradation adjustment?!?! I forgot the name of the setting but I'd be willing to bet it has something to do with the admin security level.
kingarthur
08-15-2014, 04:38 PM
i know that the touch panel adj has been removed from the set up with the latest firmware, got a feeling the gradation is no longer necessary on set up too...
jotunn
08-15-2014, 07:55 PM
Check if software switch 25 is set properly for your firmware.
Thanks guys will have a try on the security settings and software switch.
blackcat4866
08-16-2014, 12:26 AM
Do you have a key counter connected to the machine? A whole lot of functions disappear when you enable the key counter. =^..^=
rrrohan
08-18-2014, 02:53 PM
Do a firmware update but hold down reset button when you turn power on same as you would for a trouble reset. This will open a automatic touch panel calibration. Once this is done it will continue on to the firmware update
mendelieves
10-15-2015, 03:58 PM
something new? switch 25 no work....
