View Full Version : Miscellaneous bizhub c452 with p8
MARDSO
08-28-2014, 06:13 PM
I have a bizhub C452 that was showing the code p5, itc sensor! I removed the belt to clean the sensor and after doing this the machine returned with the code and not p8 leaves yellow !!! already changed the unit and cleaned the grounds of the imaging unit and belt !!! any idea? Please help me? :(
occus
08-29-2014, 12:40 PM
Unplug the IDC and reseat.
Sometime you get failure of IU color, check solid pattern... have you light background or a little scratch in the line of idc-sensor.
Check laser skew or reset laser skew.
Clean contacts of IBT and transferroller
