View Full Version : i am a Vietnamese, i need help abount IP601 and konica 7075
imavietnamese
04-18-2008, 01:02 PM
Hello Friends! I'm a Vietnamese, i have 3 Konica 7075 prints and an IP601 print server. Now i need to config or install the IP601 and the Konica 7075 to print, but i don't know how to do it. I don't have anything (book, CD, software,...). Can you show me the way to config or install it.
Thanks so much.
Sorry, My English is very bad.
doma873
04-18-2008, 02:21 PM
Hi
When you IP601 is connected to the 7075 turn the 7075 on and after about 5 minutes the machine will print a config page with ip adress etc....
You can the log into the ip601 through a web browser using the ip address, just make sure you pc is in the same ip range. Once you set the ip address you the need to download the driver from the konica web site. The pcl driver should be ok, When you load the driver onto your local pc make sure you select standard tcp/ip port. then enter the port name which i put the ip address. The browes to the driver you downloaded.
Then just go through the steps.
Well i have had a few beers so hopefully this all makes sense.
Cheers
Jomama46
04-18-2008, 05:08 PM
Having a few beers makes sense.
imavietnamese
04-19-2008, 03:56 AM
Thank you so much. I'm Trying. When you came here, in Viet Nam. Please call me. i will invite you beers. it's only to true hihi. My phone number +84904692277. But sorry my ability to speak English is verry verry bad.
Jomama46
04-19-2008, 04:14 AM
OK , I was in vietnam '61 ~62 but thats another story.
Best of Luck.
imavietnamese
04-19-2008, 04:51 AM
So, what do you think about VietNam now? and i have a new question, can i plug 3 K7075 copies to an IP601, 2 Di750 to an PI6500. and how do i do. I'm 25 year old.
