View Full Version : error c2151 konica minolta bixhub c450
javier4065
10-31-2014, 01:24 AM
my big problem is this copier. I changed the mainboard ,it is on the rear of machine.copier is ok, after a day , display said again error c2151. Why does the mainboard is bad again? what can I do? What iintegrade circuit is bad on the mainboard? thanks in advance.
laitang
10-31-2014, 06:42 AM
C2151: 2nd Image Transfer Roller pressure/retraction failure
1 Check the M13 (2nd Image Transfer Pressure/Retraction Motor) connector for proper connection and correct as necessary.
2 PC29 (2nd Image Transfer Pressure/Retraction Sensor) I/O check
3 M13 operation check
4 Change PWB-MC
allan
10-31-2014, 11:05 AM
Clean the Transfer belt retraction sensor. I use a syringe bulb to do that with a pipe attached to it. I could be part a the retraction drive that is faulty. But in my experience it is the sensor. :)
javier4065
10-31-2014, 12:42 PM
I changed de sensor and motor,pwb mc, maybe it can be wires. copier worked fine one day, then display said the same error code c2151,thanks for your help another idea?
