View Full Version : 7022 Busted Feed Gear
unisys12
04-25-2008, 09:06 PM
Hey guys, I have a few of these at an account and one of them is tearing up the Paper Feed Coupling Gear three times in the past year or so.
http://img.photobucket.com/albums/v179/unisys12/Misc/KonicaPartsList.jpg
You can see the two gears in question I have highlighted here.
I have looked and looked, but can seem to find why these fears are failing. Has anyone else seen this one this machine and what might be causing this? Thanks! :cool:
Luther
04-25-2008, 10:46 PM
replace the double feed assembly and gear #22 in the diagram it was changed from a white gear to one the same color as the double gear and the very small one,hope this helps
unisys12
04-26-2008, 02:17 AM
Cool man, I will look into that and give it to my parts manager Monday. Thanks! :cool:
RockETop
04-26-2008, 02:22 AM
I had three break in a six month period on a 7030. Once I cleaned the passage through the rear frame, replaced the coupled gears (11 and 16) and the small gear above 15, never heard back! Knock on wood, I'm jinxed now.
unisys12
04-26-2008, 03:31 AM
LOL! I know that feeling! Been there and done that, got the damn t-shirt and the damn thing has holes in it! ;)
JEFFP
04-26-2008, 05:18 AM
you can replace the gears 26na17480 and 17490 with 40la17480 and 17490 from the 7228, and they dont bind and twist like the 26na ones do.
I usually just glue the two piece gears together. Clean shafts on all the gears located in this area. Also don't forget to clean the hub and shaft on the pickup tire.
dogsbody
04-26-2008, 06:02 AM
I agree, just make sure you glue them together straight and no glue squeezes out the centre otherwise it will create a load. I found an old shaft that someone hacked the rollers off that was the right size to slide the gears down when gluing them, works every time.
JEFFP
04-26-2008, 02:21 PM
I saved a shaft from a cleaning web.
