View Full Version : CQ bizhub C360 K drum requests early replacement
John Kaufmann
12-09-2014, 07:51 PM
With the K drum on a C360 rated for 120K, is there any reason why it should request replacement at 93K?
tech51
12-09-2014, 09:28 PM
The quoted figure is really an estimate, the true usage is measured in drum rotation time. If the machine is in an environment which causes it to stabilize frequently, the drum life (in copies) will go down because the drum has still rotated even though no copies are being made. I have many machines which do few colour copies but still eventually ask for replacement drums. My advice would be to install the end of life firmware and then change the drums when the quality goes off. In my experience you can easily gain 50% or more on your drums this way....
John Kaufmann
12-09-2014, 09:40 PM
Ah, of course. Now that you mention it, I have seen that in the Check Consumables list, but had not made that connection.
Will do. Thanks!
