View Full Version : C 6501 jam code 3152 (no paper inside)
selmila
12-23-2014, 11:17 AM
I dont see any jamed paper inside and i have also checked all sensors,wires and i have even swop the ADU of a working machine but the j 3152 shows.any suggestion to recover j 3252?
kalindd
12-23-2014, 12:21 PM
J-3152 - Fusing loop sensor (PS64) is turned on in the idling condition.
Did you check the sensor?
You've swapped the ADU, but did you swap the fusing unit? This sensor is located inside the fusing unit.
It can get very dirty with paper dust and toner dust, just clean it.
methogod
12-24-2014, 09:09 AM
remove fuser
take off infeed plate
its the sensor with the flag right under it...
make sure the spring is not broken. Clean sensor....
Trace wire sensor to pin out, and make sure the pin is there and not broken off...
sucks you pulled the ADU...
good luck...
selmila
12-24-2014, 07:49 PM
remove fuser
good luck...
Hi.
i have checked everything related to the jam but it is PRCB malfunction!!
I swop the PRCB in to a working machine and the working machine pops the jam code.
Is there a chance to fix the PRCB?
methogod
12-24-2014, 08:48 PM
HYTEC (hytecrepair.com)
as for VJ
