View Full Version : Bizhub 654e from C9401 to CD291
padedwalls
01-22-2015, 07:59 PM
C9401 Basically points to no lamp, but illuminates. Several in field popping this code now. Tech support suggests CCD as of late. I did a reseat of CCD & scanner connections (yes unplugged) & now lamp doesn't home or illuminate. Throws CD291 now. Error not in manual & support has me on long hold! Anyone seen CD291?
splblazer91
01-24-2015, 03:20 AM
i believe right now they are investigating a cable as a cause of this problem. that is not confirmed yet though.
CD291= CCD parameter mismatch per the manual
3.16.16 CD291
(1) Contents
Trouble type CCD parameter mismatch
Trouble code CD291
Rank C
Detection timing The CCD unit is combined with wrong firmware.
Trouble isolation -
Relevant electrical parts • CCD unit
• MFP firmware
(2) Procedure
Step Action Control signal Location of electrical components
1 Reinstall the MFP firmware. -
padedwalls
01-24-2015, 05:38 AM
3.16.16 CD291
(1) Contents
Trouble code CD291
Rank C
Trouble isolation -
• MFP firmware
(2) Procedure
Yes sir! Corrected today with our corporate trainer. Large account has had four of these go at same time... all b&w 654e's.
Where did you copy that from? Manual?
Is that the read me attached to latest K1 Firmware? CD291 is not a documented code in service manual, even KM assist did not know it! C9401 will start intermittent the eventually hard! CD291 appears after CCD change out, mine happened after doing some mere resetting of connectors, made no sense!!!
padedwalls
01-24-2015, 05:59 AM
I'll be a sob.. tech support & I both made the same mistake (though i told him was an "e" box), we didn't utilize the "e" service manual! CD291 is in fact only in the "e" manual!
I stand corrected sir ;-)
blackcat4866
01-24-2015, 03:52 PM
Any success with the CCD? Is there a scanner calibration required? =^..^=
splblazer91
01-24-2015, 07:09 PM
I actually pulled it from the C654E manual but it should be the same.
blackcat4866
06-09-2015, 12:51 AM
Has there been resolution on this topic? =^..^=
Spratt
06-09-2015, 04:20 AM
We have had a lot of intermittent C9401 errors and the fix is to replace the CCD.
The firmware needs to be re written after installing the CCD and as you have found apparently after disconnecting.
All machines we have replaced the CCD on for C9401 have not returned.
