View Full Version : Remove margin print in c450
totaldesign
02-03-2015, 03:23 PM
Hi
I have Konica Minolta c450. I want to remove print margin around paper and get a full page print. How to remove this margin?
Albonline
02-03-2015, 03:41 PM
Hi
deletion is to ensure separation from transfer belt and fuser. removing same would cause jamming and possibly damaged fuser or transfer belt. best bet is to use larger paper and trim.
darry1322
02-03-2015, 03:43 PM
You can minimize it, but would be wise not to. Not sure if it can be completely eliminated, Removing it entirely would cause image problems along the edge and fuser failures. Full bleed printing prints a standard size image onto larger paper which is then trimmed to a standard size, removing the margins.
Max
02-03-2015, 03:47 PM
Its been a while, not sure if you can remove it completely but I believe its in the Machine tab (print area,scan area) of the service mode. You can adjust the print and scan margins. In any case it will jam on the first copy because you have removed the erase margin unless you use 160gsm + paper to resist the curl. The proper way is to have edge to edge printing is to print on oversize paper then guillotine it to correct size. Never seen oversized A4 but there is an oversized A3.
mrwho
02-06-2015, 01:47 PM
Anything bigger than A4 is an oversized A4. A3 is an oversized A4.
darry1322
02-06-2015, 02:11 PM
For full bleed print you want something slightly larger than your standard size. I can't remember if the C450 supports full bleed printing anyway.
orion2005
11-10-2022, 04:04 PM
This is an Old post, but i need the answer to this question, I have tried printing on a 12.5" x 12" paper with no luck the image gets cut at the same size that if I print in 12" x 18". so I cannot print 2 A3 sheet, the printer will print 29.6cm. but I need it to print 29.7cm + 3mm bleed. so I understand that the machine can break and the sky will fall if I remove the page margin, but it will be great in someone can explain how to remove the margins so I can print at my own risk in the size I need.
Thanks in advance
emujo2
11-10-2022, 04:12 PM
And are you dealing with a C450?
Synthohol
11-10-2022, 05:23 PM
shrink the image by 2-3% and trim the void area.
there is no edge to edge printing on any office style laser copier for the reasons mentioned.
tsbservice
11-10-2022, 05:43 PM
Ha-ha, old sly Synth :D
