View Full Version : Miscellaneous Konica Minolta C253 Fax
mearmi
02-17-2015, 07:53 PM
Konica Minolta C253 cannot send fax.
It shows transferring for long time (we waited for 25-30 minutes).
then we we have to delete the job as client has copy and print jobs.
please advise any default settings in service mode?
Thanks and regards
mearmi
copier tech
02-17-2015, 08:12 PM
Press hook, do you have a dial tone?
mearmi
02-17-2015, 08:25 PM
Thanks for your reply.
yes there dial tone and we can hear fax tone from another end too. It scans and stay on transferring
wseyller
02-18-2015, 03:50 AM
Try a new phone cord. One with only two wires. Also bypass the surge if it runs through it.
Does it happens with certain numbers.
Turn on the line monitor and listen. Do you get a recording or hear anything strange.
Is this an analog line or running over fiber/voip
Try turning off ECM
Try lowering the baud rate.
If no go initialize the fax in service mode.
mearmi
02-18-2015, 12:47 PM
Try turning off ECM
Turned off ECM and lowered the baud rate.
it is working fine.
Thanks a lot
Mearmi
copier addict
02-18-2015, 09:47 PM
Is this a new fax install? Has it been working and the suddenly stopped?
Check that the marketing area is set properly.
