View Full Version : Error Code C-2804
Pandas
02-19-2015, 07:12 AM
Hi.
Power on bizhub 600 error 28-04.
The machine i have new pm and new developer.
laitang
02-19-2015, 08:12 AM
Did you reset the developer counter?
C-2804 :While in the gamma correction, the dirt correction of the gamma sensor is not sufficient
allan
02-19-2015, 11:52 AM
Dirty Gama sensor. Even a spec of toner could cause this. The end connector on the IU also gets damaged from slamming the IU into place. If the problem persists replace the endblock and the sensor board.:p
fixthecopier
02-19-2015, 12:10 PM
I have cleaned that sensor a hundred times.
Pandas
02-19-2015, 06:43 PM
[QUOTE=fixthecopier;458744]I have cleaned that sensor a hundred times.[/QUOTE
Yes .Not work
fixthecopier
02-19-2015, 09:24 PM
Yes .Not work
then you should change it.
Pandas
02-19-2015, 11:06 PM
[QUOTE=Pandas;458806]
Ok.Thanks!!
