View Full Version : bizhub 200 prints are dirty (sample attached)
eli
02-26-2015, 07:42 PM
The prints are coming out somewhat dirty and faded. What could be the problem?
28232
Hansoon
02-26-2015, 08:25 PM
Assuming that the print comes out portrait-wise (short side first) I would say worn drum/cleaning blade/developer. Drum, cleaning blade and developer should be changed according very specific instructions otherwise you will be confronted with a C-2557 service code. Time to get a tech to do it for you unless you are familiar with MFP's yourself but you still have to follow instructions carefully. There is a plethora of information in this panel about that. Here's some:
http://www.copytechnet.com/forums/konica-minolta/51950-bizhub-350-error-code-c2557.html
Hans
allan
02-26-2015, 08:46 PM
If the machine is set to SEF it normally means a developer seal got busted and the orientation was changed to get clear prints.
