View Full Version : J20-02 C364
allan
03-13-2015, 03:53 PM
Hi here is another way to fix the J20-02 problem, just glue plastic cutout (1mm thick) the the body where the hooks must catch only bottom 2 of the 3 door hooks.
look on the left in the middel 28445
Allan
Issac-brock
03-15-2015, 02:45 AM
Allan
That's a good idea. I have the new modified springs for the idle rollers on the door, gonna try them on the next j20-02 call I encounter.
allan
03-15-2015, 06:48 AM
Do you have a part number for that springs?
HoonBoy
03-15-2015, 10:26 AM
Also tried your solution in the past, also worked in some cases...
check this post as well, for springs:
http://www.copytechnet.com/forums/konica-minolta/97029-bizhub-c364e-jam-code-20-02-a.html
tech51
03-16-2015, 08:47 PM
Have you tried fitting the modified (ribbed) conveyance roller that fits in the e versions?
I've fit these a lot on the e models and it works fine.
I'm guessing it will fit as the feed unit is the same. May be worth a try.
blackcat4866
05-13-2015, 11:47 PM
I'm not seeing it allan. Is there another photo? =^..^=
allan
05-13-2015, 11:54 PM
This it the real fix.
allan
05-13-2015, 11:59 PM
Sorry don't have any other pics. Its difficult to see the plastic pieces is the same color.
i just pulls in the door by about 1mm on the front side putting more pressure on the rollers.
