View Full Version : Biz Hub 454e
antone
05-05-2015, 02:22 AM
Keeps says orginal on glass needs to keep resetting copier!
allan
05-05-2015, 04:29 AM
Look on the panel, the machine would indicate that there is an A3(or inch size) original on the glass if the DF is closed.
I got this a couple of times on C654 machines. There is 2 original length detection sensors in the scanner cavity. They work on that table 1 and tabel 2 settings under system 1 -> original size detection settings.
Only on of them work depending on the setting for table 1 or 2. It needs to be on table 1 for metric.
It depends on your marketing area setting.
Not sure but i thing some areas only ship out with one sensor.
The way i fixed it was to swap the position of the 2 sensors and then to toggle the setting from table 1 to table 2 and then back to table 1 again.
I am not sure if its a faulty sensor or just a bug. I did use the sensor check and the sensor in that position was not working ok.
but i cant see how it could be the sensor itself.
Hope this helps you.
hotfuser
05-05-2015, 10:48 AM
check the metal clamp on the CCD cable this was too tight and was removed.
SmellsHot
05-05-2015, 12:45 PM
Don't do anything mentioned above!!!
Clean the platen glass with windex and a lint free cloth. The detection sensors are super sensitive!
I have had about a dozen of these messages.....just cleaned the glass....
If you wipe your ass.......you can wipe the glass
allan
05-05-2015, 02:18 PM
Ok thanks will try that.
minimerlin
05-05-2015, 03:01 PM
Ok thanks will try that.And do the underside as well!
mo0651
05-05-2015, 10:32 PM
Run "Non-image area erase check"
