View Full Version : Error Code i need help with my bizhub 751
alkrsh2
05-11-2015, 09:24 AM
konica bizhub 751
I forget my password so i couldn,t enter to the administrator settings >> i have tried all the cods to reset the michen :mad: any help
rrrohan
05-11-2015, 02:21 PM
konica bizhub 751
Go into service mode
I cant recall if it stop 9 or stop 0 clear but one of these will give administrator password option to set the code to a new one
alkrsh2
05-12-2015, 11:09 AM
thanks for the help >>> where can i found the service mode ?????
allan
05-12-2015, 12:47 PM
konica bizhub 751
Did you change the admin password from the default? it should be"12345678"
alkrsh2
05-13-2015, 11:37 AM
yas some one did that and he forget it :mad:
KM7155
05-13-2015, 02:20 PM
are u end user or technician?
if technician, u should know what is the service mode.
mo0651
05-13-2015, 02:35 PM
I would start by writing down there code that I am going to put in the machine.:cool:
alkrsh2
05-13-2015, 04:42 PM
i am end user:(
allan
05-13-2015, 06:24 PM
I dare you to Google the service mode entry information.
if you are in there press reset to make sure your not in one on the menus and then press "stop" "0" "clear".
may the force help you from there.
rrrohan
05-14-2015, 12:48 AM
And hope the CE (service mode) password wasn't changed as well
But there are back door methods to bypass the password screen on service mode unless they firmware patched that like they have on the new models. But not a lot of techs I know ever bothered with firmware unless they had a fault it would fix since the method was more involved than other modelsa
Synaux
05-17-2015, 12:55 AM
https://www.youtube.com/watch?v=i1Sz5nV3pBg
Synaux
05-17-2015, 12:56 AM
Like what?
rrrohan
05-22-2015, 09:51 AM
Like what?
Enter service mode. Wait for password screen. Unplug a cable such as a fuser cable. This will give you a c code. If you press the menu button again it will now be in service mode without needing password.
Then stop 9
Turn off CE auth
This works on most models never tried on the B751 range admittedly
alkrsh2
05-24-2015, 06:13 PM
Enter service mode. Wait for password screen. Unplug a cable such as a fuser cable. This will give you a c code. If you press the menu button again it will now be in service mode without needing password. Then stop 9Turn off CE auth This works on most models never tried on the B751 range admittedlyUnplug a cable such as a fuser cable.???? where is this cable ???
rrrohan
05-25-2015, 05:49 AM
Are you not a tech?
alkrsh2
05-25-2015, 05:15 PM
Are you not a tech?
I'm just sad owner:(:(
mmtshina
09-20-2015, 10:18 AM
press utility , then check details, the press stop 00 stop 01 , u will move to service mode then stop zero C, u will reset ur password there:cool:
:cool:
rrrohan
09-20-2015, 12:09 PM
:cool:
But if he is just customer won't that give him reset code to forward to KM in return for a code?
Sent from my SM-G900I using Tapatalk
