View Full Version : Konica 501 import address book
Lasersupplies
05-11-2015, 11:36 AM
Hi guys,
Im trying to import an address book from one Konica 501 to another Konica 501 and upon import i receive the following import error.
"File Format Error (symbols/characters that cannot be used are used in destinations/names, etc.)"
Is there anything that needs modified in this file?
Thanks in advance
Imsdal
05-11-2015, 12:52 PM
Check the Version on both if they are the same.
If is not just erase, change and save in the notes abbr.txt
Imsdal
rrrohan
05-11-2015, 02:18 PM
Are you using data administrator?
SmellsHot
05-12-2015, 12:40 PM
I assume he is using the import/export feature from the web interface. Pagescope data administrator is quick and easy to use if you cannot get it working via import/export
Kapral
05-12-2015, 01:21 PM
Yup, I also recommend Page Scope Data Administrator. Works as charm.
