Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Field Supervisor 500+ Posts
    Join Date
    Apr 2014
    Location
    Los Angeles
    517
    Rep Power
    30
    Brother MFC L8900 CDW intermittent prints are reduced to half size with several diffe
    Hi guys, i have a customer that said maybe once a day, when they are printing, the print comes out about half size. they turn off the machine and then its ok.
    it doesn't matter what program they are using, and several computers are all doing this. sometimes email, checks, etc.
    i would think if they had inadvertently selected a reduced or fill to page, print actual size, etc, then all the computers wouldn't do this, nor would rebooting the copier resolve that issue.
    i am sort of perplexed at this point. and being intermittent, well, that's harder.
    does anyone happen to have any ideas, or experience with this type issue??
    thank you very much, Jim
  2. #2
    Service Manager 5,000+ Posts tsbservice's Avatar
    Join Date
    May 2007
    7,145
    Rep Power
    346
    Re: Brother MFC L8900 CDW intermittent prints are reduced to half size with several d
    At first I will blame program/PC for this problem, but obviously that wouldn't apply in your case. I could think of 2 remedy:
    1. Update Firmware - think latest is L 1.10
    2. Initialize EEPROM parameters (function code: 01, 91)
    I don't reply to private messages from end users.
  3. #3
    Join Date
    Apr 2014
    Location
    Los Angeles
    517
    Rep Power
    30
    thank you TSBService. i will try those things.
    and sorry for the multi posts. they kept failing.
    have a very nice day.
  4. #4
    Join Date
    Apr 2014
    Location
    Los Angeles
    517
    Rep Power
    30
    Hi guys,
    I have updated the firmware, and the issue is still happening intermittently. now here's an interesting observation. the print is reduced one way, but not the other.
    another words, prints are to narrow from left to right, but the height from top to bottom is ok.
    any additional ideas? thank you very much, Jim
  5. #5
    Senior Tech. 2,500+ Posts NeoMatrix's Avatar
    Join Date
    Nov 2010
    Location
    Sunshine State QLD.
    3,514
    Rep Power
    104
    Sounds like a scanner timing or drum timing issue.
    Is the ITB slipping ?
    PCU's and Dev units turning freely?
  6. #6
    Master Of The Obvious 10,000+ Posts
    blackcat4866's Avatar
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,471
    Rep Power
    463
    I've seen a failing LSU cause distorted images, and images shifted 2" off one side of the page, on a Sharp. Nothing on a Brother.
    Is your information anecdotal, or can you see specific instances of it happening, and what functions are in use at that time? I've come to understand that such second-hand information like this can be slightly false or completely false, and the accounts colored by the amount of drama desired by the storyteller.
    Let's see some of those samples. =^..^=
  7. #7
    Join Date
    Apr 2014
    Location
    Los Angeles
    517
    Rep Power
    30
    so for example, when they print a check and it happens, the info fits top to bottom, but all the info that goes in certain areas on the blank check, is all shifted to the right about the middle of the page over to the right. nothing is missing, just the size is 50% narrower than normal. so its scruntched into half the page horizontally.
    i will try to get a smaple.
  8. #8
    Join Date
    Apr 2014
    Location
    Los Angeles
    517
    Rep Power
    30
    lets see if this uploads. i haven't done it much on this site.
    the image isn't the clearest, but its a blank check for printers, with the printed info all on the right half of the page. but the height is ok.
    well, when i follow the sites instructions to drag and drop to that pane, i get another window that opens, but its not attached to the copytechnet page?? maybe it takes a while to be reviewed?
  9. #9
    Join Date
    May 2007
    7,145
    Rep Power
    346
    Can you print 77 list from service mode? There will be the last 10 errors, may find something like a service code related to abnormalities. Also text shrift is halfsized and then shifted to the right or just space between symbols are narrowed and shifted. Please try again to upload sample if possible.
  10. #10
    Join Date
    Apr 2014
    Location
    Los Angeles
    517
    Rep Power
    30
    the upload system is whacko.
    i see the generic PDF icon in the "manage attachments" pane, but i dont see it here.
    Attached Files Attached Files
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
