Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Ir2200
  1. #1
    Senior Tech 100+ Posts
    Join Date
    Nov 2007
    136
    Rep Power
    0
    Ir2200
    Hi Guys I know this is a very old machine but slight problem The machine takes a while to warm up and then when you make a copy it does not come ready for about 10 seconds after copy is delivered..Hard drive problem i am thinking?
  2. #2
    Field Supervisor 500+ Posts roho's Avatar
    Join Date
    Mar 2009
    Location
    Earth
    844
    Rep Power
    43
    Re: Ir2200
    usually you get a error code for HDD issues, usually. How old is the fuser, wonder if it is keeping the right temp. Could be a few things, what have you done or tried?
  3. #3
    Join Date
    Nov 2007
    136
    Rep Power
    0
    Re: Ir2200
    Quote Originally Posted by roho View Post
    I have checked out the fuser gets to the temp that is required film and rollers are ok and No errors at all.Looks like a temp. issue but as I said reaching proper temp.
  4. #4
    Service Manager 10,000+ Posts
    Ir2200
    teckat's Avatar
    Join Date
    Jan 2010
    Location
    VA
    16,106
    Rep Power
    244
    Re: Ir2200
    Quote Originally Posted by logonjim View Post
    Did u check wall voltage outlet for correct supply ?
  5. #5
    Join Date
    Nov 2007
    136
    Rep Power
    0
    Re: Ir2200
    Hello Teckat No I have not checked that out . The machine is in an office on its own and other electrical items working ok I might try a change of fuser if I can locate one tks for tip
  6. #6
    Ir2200
    Phil B.'s Avatar
    Join Date
    Jul 2016
    Location
    Raleigh NC
    22,787
    Rep Power
    661
    Re: Ir2200
    check the wall voltage before replacing anything... drops or spikes can really muck up the works.
  7. #7
    Join Date
    Nov 2007
    136
    Rep Power
    0
    Re: Ir2200
    Ok Guys wall voltage ok constant at 230V the machine produced the dreaded error code today E602-003 so must have been a Hard Drive problem all along I removed and cleaned the Dimm so I guess that is the end of a great machine as there are no Hard drives available I cant even get into the service mode to do a check disc
  8. #8
    Ir2200
    teckat's Avatar
    Join Date
    Jan 2010
    Location
    VA
    16,106
    Rep Power
    244
    Re: Ir2200
    Try holding down 1 and 9 key while powering on printer, this puts printer hdd into defrag mode
    Shows white blocks dropping on menu, u may get a NG if HDD is bad
    Old refurbished had available online.
    Amazon.com: Buying Choices: HDD Hard disk for IR2200 2800 3300 ir2800 ir3300 FK4-0927-000
  9. #9
    Service Manager 2,500+ Posts
    Ir2200
    Join Date
    Sep 2005
    Location
    South Jersey
    3,853
    Rep Power
    133
    Re: Ir2200
    I may have a hard drive with the IR2200 system software installed on it. PM me if you still need it?
  10. #10
    Join Date
    Apr 2009
    Location
    NIAMEY
    107
    Rep Power
    0
    Re: Ir2200
    Hi, you can change the HDD and download the firmware.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
