Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 6 of 6
  1. #1
    Trusted Tech 50+ Posts
    Join Date
    Jan 2018
    63
    Rep Power
    13
    IR 6055i won't load up
    Upon turning on, loading bar reaches half, then machine resets.
    Machine is Canon iR 6055i.
    Any ideas? Thanks.
    Sent from my Moto E (4) Plus using Tapatalk
  2. #2
    Service Manager 10,000+ Posts
    Phil B.'s Avatar
    Join Date
    Jul 2016
    Location
    Raleigh NC
    22,792
    Rep Power
    661
    Re: IR 6055i won't load up
    Quote Originally Posted by darkocg88 View Post
    Upon turning on, loading bar reaches half, then machine resets. Machine is Canon iR 6055i. Any ideas? Thanks.
    what have you tried?
    could be HDD - firmware - other component
  3. #3
    Join Date
    Jan 2018
    63
    Rep Power
    13
    2 8 boot, still restarts. I think it's PCB1, just need second opinion.
    Can't do firmware update, restarts within 20 seconds max.
  4. #4
    teacher-guide-expert-guru 2,500+ Posts
    zoraldinho's Avatar
    Join Date
    Mar 2008
    Location
    SVN
    4,948
    Rep Power
    106
    Clean and reseat all contacts,memory.....
    Do you have fax board installed?
    What happen if you turn on copier with hdd unplugged?
    Practice makes perfect
    If you want something done right, you have to do it yourself
  5. #5
    Field Supervisor 500+ Posts dan7777's Avatar
    Join Date
    Dec 2012
    Location
    Bristol
    680
    Rep Power
    35
    Restart may be ram. I was thinking HD until you said that. Seems like you could boot to HD, format and reload software but I have had computers (was ram) and one Canon that did that but it would start and run a while before rebooting and they traded it in because they let the maintenance contract expire. Also main controller but not sure if that has two like some of the other ones. Glad it is not me.
  6. #6
    Tech Specialist 1,000+ Posts Canuck's Avatar
    Join Date
    Nov 2007
    Location
    Southwestern Ontario
    1,713
    Rep Power
    63
    Reseat any RAM. Disconnect finisher,etc, open all doors, drawers, etc then try to reboot after unplugging from wall and plugging back in. Can you run a Main-con or Boot Check?
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
