Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Senior Tech 100+ Posts
    Join Date
    Jan 2011
    220
    Rep Power
    29
    IR5055 Error Code E040-010
    Hello guys,
    Need to know this error code details for this machine. Its not in our manual
  2. #2
    Service Manager 10,000+ Posts
    teckat's Avatar
    Join Date
    Jan 2010
    Location
    VA
    16,106
    Rep Power
    244
    Quote Originally Posted by vishop View Post
    Hello guys,
    are u sure that is the correct read out on panel E040 ??
    only seen that code on a CLC for cassette/mf lifter motors
    also may have been for the CLC deck also-
  3. #3
    Join Date
    Jan 2011
    220
    Rep Power
    29
    Quote Originally Posted by teckat View Post
    yes teckat, its confirmed code, E040 for IR5055n, thats what my fellow technician told me, its not found in the service manual for IR5055/5075.. Anyway he also doubt that part(lifter motor), and going to check for it...
    Thank you teckat, will give you feedback as to what the outcome is...
  4. #4
    Service Manager 1,000+ Posts
    charm5496's Avatar
    Join Date
    Apr 2008
    2,388
    Rep Power
    64
    I have also seen this error on the IRC-5180 series, but it had to do with the fixing/feeder sensor and switch assembly which does not apply to this model. I can't find anything for this error pertaining to the error you are having.
  5. #5
    teckat's Avatar
    Join Date
    Jan 2010
    Location
    VA
    16,106
    Rep Power
    244
    are u sure it is not an ALARM CODE ?? if so , it would be 04-0001 for deck lifter m
    when did this tech note the code ??
    is the printer up or down ??
    what are the other Error codes shown in log ?
    does printer heat up ?
  6. #6
    teckat's Avatar
    Join Date
    Jan 2010
    Location
    VA
    16,106
    Rep Power
    244
    If it is an Alarm Code 040011
    Alarm is for right deck retry to pick up failure.
  7. #7
    Join Date
    Jan 2011
    220
    Rep Power
    29
    The error code noted on the screen is read as E0004000-01000. Anybody can interpret this and where does this error point to?
    A fellow tech says its read as E040 while another one says its E400.
  8. #8
    Gamut's Avatar
    Join Date
    Jul 2008
    216
    Rep Power
    35
    Are you sure it's not E004, get him to check fuser then try error clear, and report back.
  9. #9
    Join Date
    Jan 2011
    220
    Rep Power
    29
    its not fuser problem.
  10. #10
    Join Date
    Jul 2008
    195
    Rep Power
    33
    hi,you have a E400 code is it to do with the feeder DADF.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
