Dear all,
I have problem with my canon ir3300, if copy in plate glass it's good,
But, when i copy from ADF, the margin different with original, it's different about 3 cm then original.
Notes: i use paper 215x330 cm.
Thx for your help.
Dear all,
Thx for your help.
U1: FOOLSCAP-- is your paper tray set for U1
COPIER>OPTION>BODY>SCANSLCT - set to "0"
Use it to enable or disable the original size detection mechanism for the
ADF.
• When enabled, the scan size is determined in relation to the original
size.
Settings = 0: off (default), 1: on
COPIER>OPTION>BODY>SENS-CNF-set to "0"
Use it to set the arrangement of the original sensors.
Settings = 0: AB-configuration (default, 1: Inch-configuration, 2: A-configuration)
Caution- If you have changed the arrangement of the original sensors, select the appropriate
setting to suit the new arrangement.
COPIER>OPTION>USER>MF-LG-ST-set to "1"
Use it to indicate the Extra Length key for paper up to 630 mm long
(multifeeder, free; the ADF will also accommodate paper up to 630 mm
long).
Settings = 0: normal mode (default), 1: extra length mode (key indicated)
Dear member,
I have problem with my canon ir 3300 while coping from ADF, paper options are not coming in the feeder settings, how to obtain that. Can any one guide me.
Udayan
Sir, I can't see the options as you shown in the video. I like to know how to obtain the options. Like A4, A3, etc.
My machine not showing the paper options, there. thanks,
Udayan
Sorry, wrong model on video ----disregard
In service mode
COPIER>OPTION>BODY
MODEL-SZ
Use it to select the mode of indication by destination and of the ADF original
size detection.
Settings
0: AB (6R5E),
1: INCH (5R4E),
2: A (3R3E),
3: AB/INCH (6R5E)
ADF.
size.
Settings
0: off (default),
1: on
COPIER>OPTION>USER
MF-LG-ST
Use it to indicate the Extra Length key for paper up to 630 mm long (multifeeder, free; the ADF will also accommodate paper up to 630 mm
long).
Settings: 0: normal mode (default), 1: extra length mode (key indicated)
is this how your control panel screen shows
In service mode
COPIER>OPTION>ACC
DK-P
Use it to select a paper size for use in the paper deck.
Caution After making a selection, be sure to turn off and then on the main power
switch.
Settings 0: A4 (default), 1: B5, 2: LTR, 3: A-LTR
Have you done this cassette adjustments ??????????
sir, i will try this and see whether the options in feeder and feedsize coming or not. then i will reply to you thanks in advance.
udayan
[QUOTE=teckat;698400]
Nothing i can't have size in FEEDSIZE, as well as i can't see TRY-WIDE. can you help me, i think there is problem with some settings.
udayan
Bookmarks
