Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Join Date
    Jun 2008
    16
    Rep Power
    33
    Canon Advance IRC 2225i Clicking Drums
    Hi all,
    I have a canon Advance Irc2225i that has been in a customers for less than a year, and has begun to have clicking drums.
    We have changed two but it seems to be going along the line ie black, cyan now magenta.
    The machine has only done 12k. There must be something else causing this but i cant figure it.
    The drums turn freely enough by hand, i noticed another post on this subject that mentioned a reference to a technical bulletin regarding this problem. But nothing was posted, could anyone enlighten me further or suggest what is causing theis problem?
    Thanks in anticipation
    Tibs
  2. #2
    East Coast Imaging 2,500+ Posts
    SCREWTAPE's Avatar
    Join Date
    Jan 2009
    Location
    New York City
    3,397
    Rep Power
    70
    Re: Canon Advance IRC 2225i Clicking Drums
    Quote Originally Posted by tibs View Post
    Hi all,
    Tibs
    What makes you think that its the drum that's clicking.
    I can't find no tech pub on what your experiencing.
    Open up the back and inspect.
    Canon Copier Repair Service. Sales, Parts & Toner. NYC/NJ area. Contact:East Coast Imaging Solutions,LLC
  3. #3
    Join Date
    Jun 2008
    16
    Rep Power
    33
    Quote Originally Posted by SCREWTAPE View Post
    Thanks for getting back, i've removed the drum and it stops making a noise then replaced the drum and no noise.
    I have had to change two drums due to the same problem over the last couple of months.
    First the black drum( same problem0, then the Cyan now the magenta has begun to click.
    As i stated it has only done 12k and has been in the customers 10 months, all i've been told is that underuse is as bad as overuse.
    Apparently the ITB assy was changed under warranty within the first 2 months.
    Tibs
  4. #4
    Trusted Tech 50+ Posts
    Join Date
    Jan 2008
    67
    Rep Power
    34
    Hi Tibs,
    This symptom is quite popular for most drum unit of Canon iRAC2000 and iRAC2200 series.
    Canon has issued a technical bulletin how to detect drum unit cause clicking noise
    and the solution is replace that drum unit. However it is costly if do like that
    I have double-checked defective drum unit and find out the reason is two gears of waste toner unit.
    They make noise during rotation. To save money to solve that problem, you have to modify those gears
    instead of replacing whole drum unit. Or re-use waste toner unit of other normal drum unit, no need to care which color drum
    That waste toner unit is same for all drum unit.
    Hope this help you.
  5. #5
    Join Date
    Jun 2008
    16
    Rep Power
    33
    Quote Originally Posted by nghialuuvn View Post
    Hi Tibs,
    Hope this help you.
    Thank you, i will take apart a defective unit i have and see what i can do.
    Any chance of a picture to make sure i'm looking at the right gears?
    Many thanks
  6. #6
    Service Manager 250+ Posts
    Join Date
    Sep 2011
    Location
    Cambridge
    274
    Rep Power
    28
    I have had a few drums do this as well, so far I have been replacing them as well. I will take a look at the waste toner gears as well and report back.
    Any chances of the technical bulletin?
    V
  7. #7
    Join Date
    Jan 2008
    67
    Rep Power
    34
    Hi Tibs,
    Please see attached file for your reference
    Thanks!
  8. #8
    Join Date
    Jun 2008
    16
    Rep Power
    33
    Thanks nghialuuvn,
    now all i need to do is solve the problem !!!
    Do you have the technical bulletin that i can use as a reference?
    As you've said yourself changing drums all the time isn't cost effective and there must be a solution.
    Though it doesnt surprise me anymore with Canon that they havn't produced a solution other than changing the drums wholely.
    thanks again
    Tibs
  9. #9
    Join Date
    Jan 2008
    67
    Rep Power
    34
    Hi Tibs,
    There is no official technical bulletin about stuck of gears in drum unit.
    You have to do modification by yourself if you want to save cost.
    Good luck to you
    Luu
  10. #10
    Tech Specialist 1,000+ Posts Canuck's Avatar
    Join Date
    Nov 2007
    Location
    Southwestern Ontario
    1,713
    Rep Power
    63
    Upstream and downsream brushes go to crap on these units,especially black. If you are gonna change parts on the drum unit,I would consider if its worth it. No waste generated by the drum...residual is charged by brushes then attracted back to dev....no blade,not even a cleaner assembly.Waste on this machine is generated by the itb. What if you make just a black copy? On this machine,the color has dev motors and drum motors. The black drum and dev is driven by the itb motor
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
