Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Join Date
    Jul 2011
    Location
    Bs. As
    15
    Rep Power
    26
    Ricoh MP4500 donīt print with "Deleting file" message
    Hi
    I have a Ricoh MP4500 with the following trouble.
    When send a printout, the data reception indicator flashes, "Printing" appears on the display and a couple of seconds later "Deleting file" appears, without printing anything.
    ŋ There is some configuration that causes this ?
  2. #2
    Retired 10,000+ Posts
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,242
    Rep Power
    992
    Re: Ricoh MP4500 donīt print with "Deleting file" message
    Typical symptom when the user code is missing or incorrect.
  3. #3
    IT Manager 10,000+ Posts bsm2's Avatar
    Join Date
    Feb 2008
    Location
    Biden 2024
    26,017
    Rep Power
    336
    Are you printing from a Mac? Needs PS option
  4. #4
    Join Date
    Jul 2011
    Location
    Bs. As
    15
    Rep Power
    26
    Quote Originally Posted by slimslob View Post
    The machine did not have a user code.
    Also do the procedure SP 5-404 and delete all the accounts SP 5-846-50, but it did not work
    Thanks for your reply.
    Quote Originally Posted by bsm2 View Post
    It is not a Mac system, but it also has PS
  5. #5
    Join Date
    Feb 2008
    Location
    Biden 2024
    26,017
    Rep Power
    336
    Quote Originally Posted by Fogonazo View Post
    What print driver? load PCL 6 driver print using ipaddress and raw 9100 port
  6. #6
    Join Date
    Jul 2011
    Location
    Bs. As
    15
    Rep Power
    26
    It is configured by: TCP / IP
    Protocol: RAW
    Port: 9100
    Thanks for answering
    Is there any way to take the printer to original factory settings?
  7. #7
    Join Date
    Feb 2008
    Location
    Biden 2024
    26,017
    Rep Power
    336
    Protocol: RAW
    Port: 9100
    Setup a new printer driver and test , if it still wont print recheck the authentication and codes are OFF .. Another question ping device with machine off
    if you get a reply from that ipaddress you have a another device with the same ipaddress on the network
  8. #8
    Just a tech 250+ Posts keithxxiii's Avatar
    Join Date
    Nov 2014
    464
    Rep Power
    28
    Network Security Level?
    Access Control enabled?
    Enhanced External Charge Unit Management (printer ON)?
    Is Virtual Printer ON?
    Do an NCS reset (SP 5801-011)
    Aye! Cut the crap
  9. #9
    Service Manager 5,000+ Posts
    copier tech's Avatar
    Join Date
    Jan 2014
    Location
    London
    7,561
    Rep Power
    182
    Quote Originally Posted by keithxxiii View Post
    As suggested above i'd do a network reset.
    Also have you tried printing from your laptop bypassing the network?
    And updating the firmware would also be a good idea, possibly corrupt fw.
  10. #10
    Join Date
    Jul 2011
    Location
    Bs. As
    15
    Rep Power
    26
    Tests:SP 5801-011 Result: None
    Change equipment to an exclusive network: None
    Set up a new printer driver: None
    Control equipment from another PC: None
    I think I have a corrupt firmware problem
    Thank you for your answers Ą
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
