I'm currently having troubles setting up Scan PDF to folder with an Aficio 3025. I am testing this out on Windows XP in a WORKGROUP environment. I have a netgear router with the default gateway and router access set as 192.168.2.1. I have manually set my ip on the Ricoh machine with the default gateway and correct subnet mask. I enabled a shared folder called "scans" on my workstation computer. From the Ricoh machines menu I can access my scans shared folder and ping it both by name and ip. (\\192.168.2.11\scans). I can ping the machine from my command prompt on the computer. I have done the Ricoh testing and it says succeeded connection with pc. I can print no problems. To print I installed a universal printer driver for the Aficios from there site. Is there a scanner driver ? The connectivity between both is good. I have enabled WINS on my machine. I have disabled the windows firewall and have no 3rd party security software running. I read that you can scan to folder directly to PDF. I prefer not to have to use the TWAIN LiteBinder software that the machine offers. I see that there is SMB on the machine but do not know what that means. I have spent a few hours on this and would love any advice offered. If you need more details please let me know and I can give them to you.
Bookmarks
