0
0
Dislikes:
0
How to program a risograph RZ220 drum
Does anyone have step by step instructions for How to program a risograph RZ220 drum. The drum is brand new right out of the box.
thanks
rodney
Re: How to program a risograph RZ220 drum
Print Cylinder (Drum) Preparation
1) Remove three Shock absorbing blocks from the Print cylinder (drum).
2) Insert an ink cartridge into the Print cylinder (drum).
Lead ink to the nozzle of the cartridge in advance.
Important !
Be sure that the Print cylinder (drum) temperature is above 59 °F (10 °C).
3) Plug the power cord of the printer and start up the test mode.
Important !
Be sure that there is no Print cylinder (drum) installed in the printer at this point.
4) Install the Print cylinder (drum) in the printer. Press the Reset key after the error code “No.d04-534” appears.
5) Input the test item code “No. 117” and press the Start key.
6) Input the test item code “No. 890” and press the Start key.
7) Once turn the power switch off and start up the test mode again.
8) Input the test item code “No. 887” and press the Start key. When the ink supply action is completed, a buzzer
sounds.
NOTE : If the action is interrupted, restart the test mode “No.887”.
9) Restart the printer to quit the test mode.
2. Operation Check
1) Make a master with Riso test chart No.8 and print 200 copies at speed 3.
2) Check density balance and if necessary, re-adjust the gap between Squeegee roller and Print cylinder (drum) body.
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Bookmarks
