Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 3 of 3
  1. #1
    Trusted Tech 50+ Posts
    Join Date
    Jun 2011
    Location
    Smithtown
    61
    Rep Power
    0
    Standard SD 450 Error SC 06-00
    was running fine yesterday after it was repaired, went to go run some copies and it shot out 2 then coded out, if i take out the master roll / then the eject box / then the drum and put it all back in while the machine is off it will pass a few more copies then do the same thing again
    so if anyone knows what this code is or knows how to fix it lemme know lol
  2. #2
    Senior Tech 100+ Posts
    Join Date
    Nov 2007
    Location
    spring valley, new york
    218
    Rep Power
    39
    Pressure plate does not move from home to the master eject ready position
    The pressure plate does not reach the master eject ready position after it has left home within 3 seconds after the pressure plate motor on signal is generated.
    Pressure plate does not return to the home position
    The pressure plate does not reach the home position within 6 seconds after the pressure plate motor on signal is generated.
    Pressure plate does not move to the compression position
    The pressure plate does not reach home while traveling from the master eject ready position to the compression position within 6 seconds after the pressure plate
  3. #3
    Service Manager 5,000+ Posts
    Join Date
    Jan 2006
    Location
    Las Vegas, NV
    9,940
    Rep Power
    154
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Just Manuals | The Internet's largest selection of manuals | Instant Downloads
    Paul@justmanuals.com
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
