Thanks Thanks:  0
Dislikes Dislikes:  0
Results 1 to 6 of 6
  1. #1
    Senior Tech 100+ Posts
    Join Date
    Apr 2016
    Location
    astoria or
    200
    Rep Power
    22
    hp 4015 loud noise
    So I have a hp4015 that has a loud noise when I use tray 2, when using the bypass its quiet.
    fuser gears are fine, swing gears are good, only thing i see that is worn are the tray 2 feed pulleys, but its not jamming out of tray 2.
    can the worn tires cause a noise? Ideas please!!
  2. #2
    Join Date
    Nov 2011
    41
    Rep Power
    26
    Re: hp 4015 loud noise
    Check separation clutch (torque limiter). It could be dragging causing the noise.
  3. #3
    Service Manager 10,000+ Posts
    hp 4015 loud noise
    Phil B.'s Avatar
    Join Date
    Jul 2016
    Location
    Raleigh NC
    22,788
    Rep Power
    661
    Quote Originally Posted by craigster View Post
    what kind of load noise? squeal.... moan...gear rattle?
    worn feeds will make a sound a moaning
    bushings in feed will squeal
    and gear.. well nuff said there
  4. #4
    GARZA
    Guest
    Have you checked the paper feed assy. & registration assy. also the T-2 clutch? You have to remove T-1 multi-pass in order to get a good lQQk at the assembly. Or it could be a bad paper tray?
  5. #5
    Service Manager 1,000+ Posts theengel's Avatar
    Join Date
    Nov 2011
    Location
    North Bend
    1,780
    Rep Power
    51
    You say the swing gears are fine, but does that mean you replaced them? The way most machines are set up, they run faster out of tray 2 than tray 1, and those swing plate gears (along with the fuser gears) make the noise. You can't really see the hidden white gear in the swing plate ass., so the only way to know it's fine is replace it. Also, the worn bushings on the press roller on the fuser unit can make it loud. An old or a cheaply refurbed fuser can be loud, even though you can't see anything wrong with the gears. What happens is that the fuser gear isn't pressing up against the swing plate gear hard enough to get a good fit, and it grinds. Eventually, it'll skip and jam.
    If it has more than 500,000 on it, I'd start with the swing plate ass. Kind of a pain on this model.
  6. #6
    Field Supervisor 500+ Posts Wild Bill's Avatar
    Join Date
    Jul 2005
    Location
    Fresno, California
    774
    Rep Power
    55
    Definitely swing plate and Fuser. These machines are extremely loud right out of the box. Check not only the wear on the Brown gears teeth (up against the fuser) But check the wobble. They wear out where it rides on the shaft of the swing plate. If you really need more help here's an article and video on replacing the swing plate.
    https://diyoffice.wordpress.com/2015...ustainability/
    Izzy
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
