Thanks Thanks:  0
Dislikes Dislikes:  0
Results 1 to 8 of 8
  1. #1
    Field Supervisor 500+ Posts
    Join Date
    Apr 2014
    Location
    Los Angeles
    517
    Rep Power
    30
    HP office jet X476dn MFP (the high speed inkjet all in one) with print bar jam, open
    this darn thing don't make no sense. the display will show "print bar jam" and a short video and description of how to "open the ink access door, remove any obstructions and close the door. once done, touch OK." but there isn't anything in there. its just a cavity that holds the ink cartridges? i have looked inside at the ? web station that slides over and back, the ? wiper scanner. after resetting it, it might work for a while, maybe not. the customer said that lately when they attempt to perform a print head cleaning, it will only start and freeze up on the first stage. they unplug and it may go into the 2nd stage next time, but never finishes.
    does any one know what to make of this error? any help would be greatly appreciated. thank you very much. have a nice day, Jim
  2. #2
    Service Manager 10,000+ Posts
    Phil B.'s Avatar
    Join Date
    Jul 2016
    Location
    Raleigh NC
    22,659
    Rep Power
    658
    Re: HP office jet X476dn MFP (the high speed inkjet all in one) with print bar jam, o
    ink bar is the actual " printhead assmy.. may take some disassembly to get to look at it
  3. #3
    Join Date
    Apr 2014
    Location
    Los Angeles
    517
    Rep Power
    30
    Quote Originally Posted by Phil B. View Post
    but as i understand it, the print head/ bar in those machines is stationary?? adding to the confusion.
  4. #4
    Phil B.'s Avatar
    Join Date
    Jul 2016
    Location
    Raleigh NC
    22,659
    Rep Power
    658
    Quote Originally Posted by tonerjockey View Post
    yes stationary... it sits left to right in the body of the machine.. more than likely there is paper caught under the bar.
  5. #5
    Join Date
    Apr 2014
    Location
    Los Angeles
    517
    Rep Power
    30
    yea, i was able to look at some of the "bar" with a mirror and didn't see anything in there. i also got a pretty good look at the cleaning roller web that is inside above where the copy receiving tray is. nothing i could find in there. is there a sensor that would cause this error indication that could be dirty? yes, its a pain to get in there. thanks.
  6. #6
    Phil B.'s Avatar
    Join Date
    Jul 2016
    Location
    Raleigh NC
    22,659
    Rep Power
    658
    yup if no paper then it would be a sensor.. start with the paper sully and work your way to the output area.. it it doesn't move or wiggles too much thats the one...if you have a dental pick ( right angle ) push it in behind the sensor flag.. could be a chunk of paper ripped off in there... or use a big paperclip straightened with a hook at the end.
  7. #7
    Join Date
    Apr 2014
    Location
    Los Angeles
    517
    Rep Power
    30
    many of the sensors, at least inside the left side door and photo sensors. it looks like a royal pain to get it all apart? yes, do have and regularily use, my trusty dental tool. right next to my Phillips and torx
  8. #8
    Join Date
    Apr 2014
    Location
    Los Angeles
    517
    Rep Power
    30
    correction. "many of the sensors i saw are photo sensors" not the actuator style. is there a particular sensor location to check for this error? and how would anyone be able to clear a jam from the ink access hole??
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
