Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 4 of 4
  1. #1
    oldminolta
    Guest
    HP1055CM printhead counter reset
    Do You know if it is possible to reset the counter in a 1055Cm printhead unit?
    Thanks,
    Janos
  2. #2
    Technician pebkac's Avatar
    Join Date
    Oct 2014
    36
    Rep Power
    20
    Re: HP1055CM printhead counter reset
    Not that I'm aware of. Why would you want to?
    Practically every DesignJet I've worked on has had printheads that are past their expiration date or recommended usage. No big deal.
    If the device has rejected a printhead there's probably something wrong with it.
  3. #3
    oldminolta
    Guest
    You're right. This overhead has over 1200ml ink flowing, but it's still working fine.
    Thank You!
  4. #4
    Service Manager 1,000+ Posts
    Kiran Otter's Avatar
    Join Date
    Dec 2013
    1,058
    Rep Power
    54
    I've seen 10 year old printheads and inks in printers that worked just fine. If the printer displays "MONITOR" for a printhead, it means monitor the output and if you see a problem, replace that print head. The printer does slow down (essentially disables bi-directional printing) when a printhead shows MONITOR. It will say MONITOR purely because of the age of the print head; usually after 12 months of being inserted.
    There's a print quality test print you do as well which will show you how all the nozzles are working for each printhead.
    Kiran
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
