Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. #1
    Join Date
    Apr 2016
    Location
    Antananarivo
    17
    Rep Power
    17
    HP M425DN ADF issue
    Hello
    scan004.pdf
    I have the following problem with ADF. When I am trying to scan doc from ADF, the margin is incorrect on the top (offset to right side). As you can see from pdf file. Tried to clean rollers, did not help. Now I think to order the following spare parts:
    HP LaserJet Pro 400 MFP M425dn Doc Feeder (ADF) Roller Maintenance Kit, Genuine (E2914) but I am not sure will it help or not. Maybe someone can give me advice, how to fix it.
    Thank you in advance.
  2. #2
    Service Manager 1,000+ Posts theengel's Avatar
    Join Date
    Nov 2011
    Location
    North Bend
    1,780
    Rep Power
    51
    Re: HP M425DN ADF issue
    It doesn't look incorrect to me. It looks crooked, but not incorrect.
    Those little machines just don't feed very well. Best you can do is replace rollers, and make sure the side guides are nice and tight... but not too tight.
  3. #3
    Senior Tech 250+ Posts driving lots of miles's Avatar
    Join Date
    Jun 2016
    Location
    Kansas
    364
    Rep Power
    22
    Also make sure one of the hinges on the ADF is not broken, it will also cause skewed copies.
  4. #4
    Join Date
    Apr 2016
    Location
    Antananarivo
    17
    Rep Power
    17
    If I understood right, I have just checked hinges ( HP LaserJet Pro 400 MFP M425dn ADF Hinge, Genuine (J8802) ) and everything is ok. It was replaced to new by warranty 1 year ago. The previous was broken. Visually there are no any problems inside the ADF, but copies still skew. Do you have service manual how to dissemble ADF and checked rollers inside the ADF (latest rollers pulling the paper.) Firstly, I will try to dissemble ADF and after replace the spare parts. I hope the problem will be fixed.
    Thank you.
  5. #5
    Join Date
    Nov 2011
    Location
    North Bend
    1,780
    Rep Power
    51
    I don't think the manual tells how to disassemble it. HP manuals have gotten really bad recently.
  6. #6
    Join Date
    Nov 2011
    Location
    North Bend
    1,780
    Rep Power
    51
    If that ADF was just replaced a year ago, unless they're scanning a whole lot of paper, it's probably not bad.
  7. #7
    Join Date
    Apr 2016
    Location
    Antananarivo
    17
    Rep Power
    17
    No, I print only 20 pages per month via ADF. Also, I figured out that there is small skew during the simple print 3 - 4 mm top and skew increased during ADF scan. The rollers were replaced to new one on ADF and did not help. Maybe something wrong with fuser?
  8. #8
    Service Manager 2,500+ Posts
    HP M425DN ADF issue
    Join Date
    Sep 2005
    Location
    South Jersey
    3,851
    Rep Power
    133
    Yes HP has decided a lot of their "junk" are "throw away" models and aren't really serviceable. Service manuals very weak. My only experience with those cheap made adf's is replacing the whole thing. Not saying that it what you need to do. The few times I replaced them was for jam light staying on after sheet fed through and some other weird problem. If I remember not many parts were sold for the ADF, just the rollers,etc. Think I had to but whole adf for a bad sensor!
  9. #9
    Service Manager 10,000+ Posts
    HP M425DN ADF issue
    Phil B.'s Avatar
    Join Date
    Jul 2016
    Location
    Raleigh NC
    22,776
    Rep Power
    661
    Quote Originally Posted by xrootx View Post
    Thank you.
    the only instructions I could find for that machines ADF is how to replace feed/sep ... there are no spare parts for the rest of the ADF. Like the others have said it's a "throw away" ADF.
  10. #10
    Join Date
    Nov 2011
    Location
    North Bend
    1,780
    Rep Power
    51
    In other words, there's not much you can do about the skew.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
