Results 1 to 10 of 10
Thread: hp dj T790
    Senior Tech 100+ Posts 1stcavvet's Avatar
    Apr 2015
    Sterling Heights, Michigan
    193
    9
    hp dj T790
    If I attach the cutter to this machine, it goes to the left side after a good print and tries to cut the paper--- travels about 5-6 inches from the left side the carrier stops and shows an 86.10 paper jam,(this is also happening with a new cutter assembly) if I remove the cutter the machine shows no problem.the machine prints and the customer has to manually cut the paper. I was thinking the rear bushing is probably gone and the carrier is dragging in the front -----Looking for any other ideas------ machine is 2-3 years old and hardly gets used
    Service Manager 1,000+ Posts theengel's Avatar
    Nov 2011
    North Bend
    1,630
    39
    Re: hp dj T790
    Have you cleaned and oiled the rail?
    If the rail was dirty and causing a lot of resistance, then the added cutter resistance could be the straw that breaks the back and finally throws up the error.
    Field Supervisor 500+ Posts
    hp dj T790
    Kiran Otter's Avatar
    Dec 2013
    561
    18
    Re: hp dj T790
    Wow, I had this EXACT problem recently. I thought it was something to do with the belt so I started to replace it. When I removed the carriage, I realized the belt wasn't even attached to it! The carriage was broken where the two posts that hold the belt to the carriage were. How it worked at all... I don't know. I think this is a result of the end user trying to force the carriage to move, either during a jam or some other time.
    hp dj T790-2017-09-18-14-59-40-jpg
    When I showed it to HP, they said yup! They'd seen that before.
    So maybe this is your problem.
    Attached Images Attached Images
    hp dj T790
    Dec 2013
    561
    18
    Re: hp dj T790
    Also, note the correct position for the belt as it threads in the carriage.
    hp dj T790-image001-jpg
    Nov 2011
    North Bend
    1,630
    39
    Re: hp dj T790
    Quote Originally Posted by Kiran Otter View Post
    I had one break there... but it wasn't moving at all. And I'm pretty sure it broke because the user was trying to force the carriage to move.
    hp dj T790
    Dec 2013
    561
    18
    Re: hp dj T790
    Any update on this, 1stcavvet? I'm curious what you found.
    Apr 2015
    193
    9
    Re: hp dj T790
    Yup!!! belt attaching area was broken the 2 outer lugs were missing, I took the carrier out of the machine and when I turned around with the carrier in my hand the belt fell on the floor I can't believe it would even print
    hp dj T790
    Dec 2013
    561
    18
    Re: hp dj T790
    Yeah, exactly what I had. Thanks for the update!
    Nov 2011
    North Bend
    1,630
    39
    Re: hp dj T790
    I wonder if there's a way to repair those with some kind of clamp. The next time I run across this, I think I'll try. The problem is that aside from keeping the belt clamped down, those two posts also affect belt size because they make a little curve in the belt.
    Apr 2015
    193
    9
    Re: hp dj T790
    Go on ebay To look at carriers t790, there's a guy in England who invented a clamp like your refering to. he's selling them for around 50.00
