Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 4 of 4
  1. #1
    kazu
    Guest
    HP LJ 1300 creases
    I changed the fuser but still the problem persists, also did halftest,Made sure print media is loaded correctly and that the guides fit properly against the media stack...
  2. #2
    Master Of The Obvious 10,000+ Posts
    HP LJ 1300 creases
    blackcat4866's Avatar
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,471
    Rep Power
    463
    Did you try some fresh paper? =^..^=
  3. #3
    Service Manager 1,000+ Posts
    HP LJ 1300 creases
    prntrfxr's Avatar
    Join Date
    Apr 2008
    Location
    Living in Exile
    1,638
    Rep Power
    58
    Fresh paper is important, but make sure that the fuser is seated properly. I don't remember for the 1300, but 1320 & P2015 have holes that accept pins from the paper guide. If the fuser is installed on top of the paper guide or the entrance guide of the fuser gets pushed out of position during installation, you can have wrinkling issues. Also, you can open the back door to allow paper to bypass the delivery asm to rule that out too. A bad cartridge can sometimes cause wrinkling. Hope all this helps you.
  4. #4
    kazu
    Guest
    Thanks guys let me try and will let you know
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
