Thanks Thanks:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Senior Tech 250+ Posts
    Join Date
    Aug 2011
    Location
    KAMPALA CITY
    275
    Rep Power
    28
    Help with HP Laserjet M2727nf
    Hi guys am working on the above printer and intermitently shows scanner error 5 and 8. I have cleaned all the optics ,lubricated the scanner rod but runs a few copies.when you switch off and on the machine it keeps,checking for the home position and brings the said errors. However ,when you manually push the scanning cursor to the extreme end,and switch on the scanner comes to the home position and gets ready.Assistance requested.Thanks in advance.
  2. #2
    Field Supervisor 500+ Posts
    Join Date
    Oct 2010
    Location
    Kampala, Uganda
    860
    Rep Power
    40
    Re: Help with HP Laserjet M2727nf
    Check by substitution, the scanner home position sensor for defect. A faulty scanner stepper motor could be another culprit. A service manual for the printer, would be of great value if u could lay your hands on one. Good luck.
  3. #3
    Service Manager 5,000+ Posts
    Join Date
    Jan 2006
    Location
    Las Vegas, NV
    9,940
    Rep Power
    154
    Lightbulb Re: Help with HP Laserjet M2727nf
    Paul@justmanuals.com
  4. #4
    Tech 100+ Posts mabawser's Avatar
    Join Date
    Sep 2009
    Location
    Glasgow
    121
    Rep Power
    31
    you will need to replace the scanner assy and even possibly a formatter board. the stepper motor goes. still not sure if the formatter takes out the scanner..... had times when ive fitted the scanner assy and never went back and at times I've fitted the scanner assy and been back the next day to fit another scanner and a formatter. (just be aware) because I an getting the same scanner error.
  5. #5
    Join Date
    Aug 2011
    Location
    KAMPALA CITY
    275
    Rep Power
    28
    Thanks guys for your suggestions i will retry and see the next step.
  6. #6
    Master Of The Obvious 10,000+ Posts
    blackcat4866's Avatar
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,468
    Rep Power
    463
    I haven't had the opportunity to try to disassemble this particular scanner. You'll find that some of these little scanners just are not intended to be disassembled. If you are able to identify a bad HPS, you may be able to substitute a photointerrupter from another part of the machine that does have a part number. For the price of the scanner assembly, your customer may decide it's just not worth fixing. =^..^=
  7. #7
    adam_system
    Guest
    Now is new service note on LaserJet M2727nf/nfs - for free exchanged unit in Hp service:
    For HP and Channel Partner Internal Use
    SUPPORT COMMUNICATION - SERVICE ACTION ADVISORY
    Document ID: c03128486
    Version: 1
    HP LaserJet M2727 MFP series - Blank display, Display hangs, Control Panel not Responding, Hangs when Initializing, Scanner Error 5 or Scanner Error 8
    Release Date: 2011-12-20
    Last Updated: 2011-12-21
    DESCRIPTION
    Products Affected Product Number(s) Affected Starting Serial Number Ending Serial Number
    LJ M2727, CB532A Not Applicable Not Applicable
    LJ M2727nfs, CB533A Not Applicable Not Applicable
    HP has an ongoing issue with M2727 formatter board failures that may affect ANY unit (NEW, REFURBISHED, or previously REPAIRED). HP is currently screening new and refurbished formatter boards in hopes of catching the bad ones. The screening process is not perfect and some defective boards may continue to be installed in new and refurbished units. Formatter failures will fall into one of the two following categories:
    Upon power up, the device may exhibit one or more of the following symptoms:
    Blank display
    Display hung at “Hewlett-Packard”
    Printer will not finish initializing
    Control panel will not respond
    Formatter problems may also lead to Scanner failure. If the device is able to boot, Scanner failure will exhibit one of the following symptoms:
    Scanner Error 5 is displayed.
    Scanner Error 8 is displayed.
    Scanner Error 5 and 8 Details:
    Scanner Error 5 - Scanner unable to find Calibration Label prior to Copy or Scan Job.
    Scanner Error 8 – Scanner unable to find Calibration Label after Copy or Scan Job.
    The Scanner must be able to find ‘home’ (calibration label) before and after Scan/Copy jobs or one of the above errors will be displayed. On a normal working unit, these error messages may appear after the useful life of the scanner has been exceeded (up to 15k jobs from the flatbed).
    In the case of this Service Advisory, the error is due to a bad formatter board that causes the scanner motor to prematurely stop working and triggering either a Scanner Error 5 or 8.
    Troubleshooting for Level 1 Agents
    Power cycle the device.
    If the error condition is still not resolved then proceed to the Scope section below.
    SCOPE
    HP is extending the 1 year Formatter and Scanner Sub Assembly warranties to 2 years from date of purchase.
    Level 1 Agents – Do your best to determine if the failing printer is within or near 2 years from date of purchase. If so, and the failing printer exhibits one of the above mentioned symptoms, follow your regional process to elevate the case for product replacement.
    Level 2 Agents – Present the below options to the customer.
    RESOLUTION
    RESOLUTION (Level 2 - Customer Satisfaction) ONLY
    Troubleshooting for Level 2 Agents - Customer Satisfaction ONLY
    For customers that have products that exhibit the symptoms listed above, HP will replace the product with a new one. Offer the customer one of the following options:
    Replace the defective unit with a NEW HP LaserJet Pro M1536 MFP (monochrome). (See ‘PRODUCT COMPARISON CHART’ below.)
    Replace the defective unit with a NEW HP LaserJet M2727. (HP cannot guarantee replacement M2727 will not again fail for same reason. The new unit will, however, be covered by standard 1 year warranty and this Service Advisory.)
    NOTE: NEW products shipped to customers will retain the entire new product warranty. (One Year for either of the above listed products.)
    Product Comparison Chart (Quick Reference for Level 2 Support)
    M1536dnf M2727nf
    Support Model Express Exchange Only Return to Bench (Repair)
    Functions Print, duplex, copy, scan, fax Print, duplex, copy, scan, fax
    Black Print Speed Up to 26 ppm Up to 27 ppm
    Black Print Resolution Up to 600 x 600 x 2 dpi Up to 1200 x 1200 dpi
    Duplex Printing Automatic (standard) Automatic (standard)
    Display 2-line LCD (text) 2.5-in LCD (text)
    Print Technology HP FastRes 1200 REt, HP FastRes, HP ProRes 1200, HP TrueRes
    Printer Memory 128 MB 64 MB
    Processor 500 MHz Freescale Coldfire V5X processor 450 MHz Motorola Coldfire V5e
    SCAN
    Black Scan Speed Up to 26 ppm Up to 3 ppm
    Color Scan Speed Up to 15 ppm Up to 3 ppm
    Scanner Resolution Optical: Up to 1200 dpi
    Enhanced: Up to 19,200 dpi Optical: Up to 1200 dpi
    Scanner Bit Depth 24-bit 24-bit
    Maximum document scan size ADF: 8.5 x 14 in
    Flatbed: 8.5 x 11.7 in ADF: 8.5 x 14 in
    Scanner input type Flatbed, ADF Flatbed, ADF
    COPY
    Copy Speed Up to 26 cpm
    (single sheet on flatbed, multiple copies) Up to 27 cpm
    Maximum number of copies Up to 99 copies Up to 99 copies
    Copy scaling 25 to 400% 25 to 400%
    FAX
    Fax transmission speed 3 sec per page 3 sec per page
    Fax resolution Up to 300 x 300 dpi
    (halftone enabled) Up to 300 x 300 dpi
    (halftone enabled)
    Incoming fax memory Up to 400 pages Up to 600 pages
    Fax speed dials Up to 120 numbers
    (119 group dials) Up to 120 numbers
    (119 group dials)
    PAPER
    Supported paper sizes Letter, Legal, A4, Executive, A5, A6, B5 (JIS), 16k, 8.5x13Custom sizes:
    Minimum: 76 x 127 mm (3 x 5 in)
    Maximum: 216 x 356 mm (8.5 x 14.0 in) Letter, Legal, A4, Executive, A3, A5, A6, B5 (JIS), 16k, 8.5x13Custom sizes:
    Duty Cycle Up to 8,000 pages (printer) Up to 15,000 pages (printer)
    Paper handling (Input) Priority Input Slot: 10 sheets
    Tray 1: 250 sheets
    ADF: 35 sheets Tray 1: 50 sheets
    Tray 2: 250 sheets
    ADF: 50 sheets
    Recommended monthly volume 500 to 2000 750 to 3000
    CONNECTIVITY
    Networking Standard (built-in Ethernet) Standard (built-in Ethernet)
    Wireless Capability No No
    Connectivity 1 USB
    1 Ethernet
    2 RJ-11 fax ports 1 USB
    1 Ethernet
    2 RJ-11 fax ports
    HP ePrint capability Yes No
    Mobile printing capability HP ePrint, Apple AirPrint™ N/A
    Parts Required
    Replacement Part Number Quantity Description
    Country Specific 1 NEW HP LaserJet Pro M1536 MFP
    Country Specific 1 NEW HP LaserJet M2727 MFP
    SERVICE ACTION
    Ensure the unit in question meets the criteria of this Service Advisory:
    Unit displays or exhibits one of the listed error messages or behaviors.
    Unit was purchased 2 years ago or less.
    If both A and B are met, replace the defective unit with one of the customer chosen NEW printers and mark the CSO as a Service Advisory.
    NOTE: Do not repair a M2727 exhibiting any of the symptoms listed in this Service Advisory. HP cannot guarantee that replacement formatter boards (new or refurbished) will not cause unit to fail again.
    Recommended Action: Refer to Resolution
    Objective: Recommended Modification
    LABOR ALLOWED
    Hours: 0
    Minutes: 0
    Service Delivery Type: HP Site
    EFFECTIVE DATES
    Start: 2012-01-01
    Expiration: 2012-12-31
    WARRANTY COVERAGE
    Labor Covered: By Warranty
    Parts Covered: By Warranty
    Travel Covered: By Warranty
    PARTS LOGISTICS
    Parts Strategy: Standard Support Process
    Service Inventory: Return
    Used Parts: Return
    Hardware Platforms Affected: HP LaserJet M2727 Multifunction Printer series
    Components Affected: Not Applicable
    Operating Systems Affected: Not Applicable
    Software Affected: Not Applicable
    Third Party Products Affected: Not Applicable
    Geographies Affected: Asia Pacific and Japan, Europe/Middle East/Africa, Latin America, Canada, United States
    Support Communication Cross Reference ID: IA03128486
    ©Copyright 2011 Hewlett-Packard Development Company, L.P.
  8. #8
    adam_system
    Guest
    Version: 1
    DESCRIPTION
    Blank display
    SCOPE
    RESOLUTION
    M1536dnf M2727nf
    SCAN
    COPY
    FAX
    (halftone enabled)
    (119 group dials)
    PAPER
    Tray 1: 250 sheets
    Tray 2: 250 sheets
    ADF: 50 sheets
    CONNECTIVITY
    Connectivity 1 USB
    1 Ethernet
    1 Ethernet
    2 RJ-11 fax ports
    Parts Required
    SERVICE ACTION
    LABOR ALLOWED
    Hours: 0
    Minutes: 0
    EFFECTIVE DATES
    Start: 2012-01-01
    WARRANTY COVERAGE
    PARTS LOGISTICS
    Used Parts: Return
  9. #9
    adam_system
    Guest
    New service note:
    Version: 1
    DESCRIPTION
    Blank display
    SCOPE
    RESOLUTION
    M1536dnf M2727nf
    SCAN
    COPY
    FAX
    (halftone enabled)
    (119 group dials)
    PAPER
    Tray 1: 250 sheets
    Tray 2: 250 sheets
    ADF: 50 sheets
    CONNECTIVITY
    Connectivity 1 USB
    1 Ethernet
    1 Ethernet
    2 RJ-11 fax ports
    Parts Required
    SERVICE ACTION
    LABOR ALLOWED
    Hours: 0
    Minutes: 0
    EFFECTIVE DATES
    Start: 2012-01-01
    WARRANTY COVERAGE
    PARTS LOGISTICS
    Used Parts: Return
  10. #10
    adam_system
    Guest
    New service note:
    Version: 1
    DESCRIPTION
    Blank display
    SCOPE
    RESOLUTION
    M1536dnf M2727nf
    SCAN
    COPY
    FAX
    (halftone enabled)
    (119 group dials)
    PAPER
    Tray 1: 250 sheets
    Tray 2: 250 sheets
    ADF: 50 sheets
    CONNECTIVITY
    Connectivity 1 USB
    1 Ethernet
    1 Ethernet
    2 RJ-11 fax ports
    Parts Required
    SERVICE ACTION
    EFFECTIVE DATES
    Start: 2012-01-01
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
