Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 5 of 5
  1. #1
    Senior Tech 100+ Posts IkeW0491's Avatar
    Join Date
    Oct 2013
    Location
    Hartsville
    172
    Rep Power
    23
    HPLJ 4345 MPF Jamming on Legal Size only
    Hi All,
    I am working on a HP LJ 4345 MFP that only wants to jam on Legal size paper.
    If I copy to Letter size or print to LEtter size there is no issue with it jamming.
    IF I copy or print to Legal size then it wants to keep jamming.
    I am getting Error Code 13.33.00 which of course means jam in top cover area.
    What could cause this type of jamming.
    I have tried removing all rollers and cleaning with alcohol.
    Thanks in advance for any assistance.
    Ike
  2. #2
    Join Date
    Oct 2013
    Location
    Hartsville
    172
    Rep Power
    23
    Re: HPLJ 4345 MPF Jamming on Legal Size only
    Well, I'll be danged
    It ended up being a piece of card stock caught in the very far edge of the top cover.
    It was in a place that when using letter size it would not effect the paper path, but when you used legal it was catching the paper and causing a jam.
    can't say for sure how it ended up in the copier, looks like part of a small box (packing for envelopes, tape,...).
    Weird!\
  3. #3
    Senior Tech 250+ Posts
    Join Date
    Nov 2010
    Location
    gardner, MA
    436
    Rep Power
    37
    Good you found the problem typing takes to long.
    jam is in reverse unit, paper not getting to ps109. try printing legal face up to see if you get a jam. since letter is not jamming going face down exit, could be something with reverse unit as 14 inch paper would go further back into reverse unit. if printing face up does not jam for legal then it would be in reverse unit guides. if it does jam in face up may be a control board issue. also make sure the tray is set for legal paper.
    Attached Files Attached Files
  4. #4
    Join Date
    Oct 2013
    Location
    Hartsville
    172
    Rep Power
    23
    Thanks for the Info Faxman,
    I saved the PDF's so I will have them for future Reference.
    I truly appreciate the info.
    IKE
  5. #5
    Service Manager 5,000+ Posts
    Join Date
    Jan 2006
    Location
    Las Vegas, NV
    9,940
    Rep Power
    153
    Lightbulb Re: HPLJ 4345 MPF Jamming on Legal Size only
    http://www.justmanuals.com
    paul@justmanuals.com
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
