Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Field Supervisor 500+ Posts
    C754e FS535 with SD unit
    copytechman's Avatar
    Join Date
    Nov 2008
    Location
    Barrie, Ontario
    909
    Rep Power
    44
    This thing is a stinker to see into, but the paper doesnt consistently fall all the way down or hangs on something when it drops causing a misalignment when it folds, all mylars look good, was considering replacing the set of 4 paddles at the bottom, I dont even think the set of 2 at the top are accessible. Any thoughts on this please, I've had the SD unit right out of the machine, theres no binding in the movement of the bottom plate. When the paper does land all the way down the fold is perfect.
    Any input would be appreciated.
    Thanks!
    A.
  2. #2
    Service Manager 1,000+ Posts
    habik's Avatar
    Join Date
    Apr 2010
    2,015
    Rep Power
    59
    Re: C754e FS535 with SD unit
    Quote Originally Posted by copytechman View Post
    Thanks!
    A.
    Check the knife movement. We had few where the kinfe on occasion was protrusing out a bit.
    Firmwares HERE
  3. #3
    Master Of The Obvious 10,000+ Posts
    blackcat4866's Avatar
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,471
    Rep Power
    463
    This is off a SD510, but might help you. I've seen these registration plates get paper cuts in the small feature right where the paper comes into the folding tray. Maybe the picture will help. I've added sheet metal "guards" to a few of these saddle stitcher guides to avoid wear at that point.
  4. #4
    Field Supervisor 500+ Posts B0265's Avatar
    Join Date
    Jan 2007
    714
    Rep Power
    47
    Check also the "grippers" and the solenoid in the stopper guide.
  5. #5
    Join Date
    Nov 2008
    Location
    Barrie, Ontario
    909
    Rep Power
    44
    Quote Originally Posted by habik View Post
    You would think it would know when the knife's at home? Can it overrun and not code out?
    Thanks!
    A.
  6. #6
    Join Date
    Nov 2008
    Location
    Barrie, Ontario
    909
    Rep Power
    44
    Quote Originally Posted by blackcat4866 View Post
    Your referring to the joggers inside the chute as it goes into where it lands on the bottom, dang those are hard to inspect, the customer did mention that they folded a lot with this particular machine. I'll have to have a second look at them.
    Thanks!
    A.
  7. #7
    Join Date
    Nov 2008
    Location
    Barrie, Ontario
    909
    Rep Power
    44
    Quote Originally Posted by B0265 View Post
    By grippers are you referring to the paddles that rotate around or the jogging plates? As for the solenoid in the stopper guide could you point out where that might be, I do have a parts manual and service manual so if i had a pn I could locate it easier... manuals can be easy to overlook things in.
    Regards!
    A.
    Edit: gotta love a theory manual that talks about a solenoid but doesnt show where it is! Found it though, its at the bottom on the assy that the paper lands on (and moves up and down) . Gonna have to have a look @ that one too. This is an SD512 btw.
    Regards!
    A.
  8. #8
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,471
    Rep Power
    463
    This is the illustration I was looking for:
  9. #9
    Join Date
    Nov 2008
    Location
    Barrie, Ontario
    909
    Rep Power
    44
    Thanks! Not quite sure if thats similar to the sd512 or not but will check again regardless!
    A.
  10. #10
    Join Date
    Nov 2008
    Location
    Barrie, Ontario
    909
    Rep Power
    44
    A.
    Update:
    Turns out that the 2 paddle rollers weren't "synced" with the markers, at least it appears that way, don't know how they got out of sync but we'll see. Stay tuned.
    A.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
