Thanks Thanks:  0
Dislikes Dislikes:  0
Results 1 to 4 of 4
  1. #1
    Service Manager 1,000+ Posts
    bizhub 454e   df 701 doc feed ( originals left on glass)
    brent's Avatar
    Join Date
    Nov 2008
    Location
    Kellogg Idaho
    1,136
    Rep Power
    44
    at first I couldn't get it to do the same problem as customer described.. then it did.. I could not get it to work while the doc feeder is completely open
    I was able to push on the actuator in the back and each time the scanner came on.. so I feel the sensor is working any thoughts on why it
    keeps saying originals left on the glass? if I shut machine off and on. it works the first time every time. any help would be appreciated
    brent
  2. #2
    Aging Tech 10,000+ Posts
    copier addict's Avatar
    Join Date
    Jul 2013
    Location
    Diamond
    12,007
    Rep Power
    325
    Re: bizhub 454e df 701 doc feed ( originals left on glass)
    Quote Originally Posted by brent View Post
    brent
    Make sure the DF is square on the scanner bed. If the magnet on the DF doesn't line up with the reed switch under the front scanner cover it will not clear the original on glass.
  3. #3
    Certified Konica Expert 2,500+ Posts
    Synthohol's Avatar
    Join Date
    Mar 2016
    Location
    North Jersey
    4,990
    Rep Power
    217
    had the same thing recently, i removed the glass and the cover around the CCD and blew it all out with an air can.
    there had to be a dirty sensor on the CCD board in my case because that fixed it.
    also a dirty platen cover will do it too. had a lot of pen marks and splatters (hows that happen?) trick it into thinking there was something on the glass.
  4. #4
    Join Date
    Apr 2009
    Location
    LaPorte Indiana
    1,054
    Rep Power
    43
    Clean the glass, perform NON-Image area erase in service mode. Your problem will be solved.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
