Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Senior Tech 250+ Posts
    CF Card issue Bizhub 601(god i hate this thing)
    DigiMan's Avatar
    Join Date
    Jan 2013
    Location
    In a gadda da vida
    262
    Rep Power
    27
    Good morning everyone..
    As the title says one of my customers 601's stopped booting and when i get there i indeed confirm it doesn't.
    Having some past experiences with this issue the first thing that came to mind is the CF card.
    Indeed when i took it to my shop and plugged it in there where only 3 files in it and they have jibberish names
    so possibly corrupted.
    Lucky for me i have a spare 601 on my shop and i just take it out copy paste everything to the other card(not formating anything)
    and i try it on my machine which it doesnt work(wont boot).Hard luck i guess im gonna order a new one.
    Thing is that my shop machine now wont work with its previous card either!WTF?
    Have i done something wrong here??Should i have done a different procedure to troubleshoot it?
    To be honest im completely lost here and desperately need some advice as i dont know what routine to follow!
    Thanks in advance!
    Edit:Can anyone confirm if you plug your cf card in your computer using a card reader and you open your computer and highlight it(or by checking the properties) does it say Vxworks in the system file?
    I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
  2. #2
    Certified Konica Expert 2,500+ Posts
    Synthohol's Avatar
    Join Date
    Mar 2016
    Location
    North Jersey
    4,990
    Rep Power
    217
    Re: CF Card issue Bizhub 601(god i hate this thing)
    Use konica cf card tool.
    The cards are not a standard format, I've had to use a hex code tool to reset zeros to the card so the cf card formatter and firmware image writer tool can do its job.
    the firmware imaging toolkit is what you have to use.
  3. #3
    Field Supervisor 500+ Posts Woxner's Avatar
    Join Date
    Jul 2011
    Location
    Felixstowe England
    783
    Rep Power
    41
    hope you save a backup copy of the shop cf card. if you transfer one to the other you will need to put the serial in the fixed machine otherwisw it will have your shop seriel. but like last post said tool is best or required. vx should show up in the computer when you look at the files
  4. #4
    DigiMan's Avatar
    Join Date
    Jan 2013
    Location
    In a gadda da vida
    262
    Rep Power
    27
    Goodmorning gentlemen
    Thank you for your replies and sorry for my late response(was in hospital for health issues ).
    The only CF card tool i found on infohub is about the old C350,can it be used for the 601's?
    As i understand i need to reload firmware on my shops card to make it work again using that tool?
    Im trying to make sense on the service manual but im having a hard time(noob!) since its a bit vague.
    If its not too much trouble can you guys guide me in steps in what needs to be done so i wont mess up
    more than i already did?
    Thanks so much!
    Edit : ok so searching throughthe forum i've found some guys using a tool that turns the cards to factory default?(Synthohol
    im guessing you mean the same thing?)Though no one said which program is it and if the procedure is available.
    Im guessing i have to turn the card to default and then reload firmware over it?A few pointers on how to do that and with what software
    would be most welcome!)Sorry if im asking pretty much the same questions over and over,first time messing with these cards.
  5. #5
    Join Date
    Nov 2016
    Location
    fort smith,ar
    12
    Rep Power
    16
    Here is an older post with some good info bizhub 601 hourglass on display. that is it Bottom line is never format the card you are trying to repair.
    A new cf card can be ordered from Konica Minolta, part # A0PNR72211 for U.S.. Pricey ... maybe $300 ish
    It will have a base firmware already on it .
  6. #6
    Service Manager 2,500+ Posts
    Join Date
    Sep 2005
    Location
    South Jersey
    3,860
    Rep Power
    133
    he said he didn't format the card. think the problem is he should've used the K/M imaging toolkit to copy.
    As far as hating that model, join the crowd. read my reply to a recent post about a 751 jamming.
  7. #7
    DigiMan's Avatar
    Join Date
    Jan 2013
    Location
    In a gadda da vida
    262
    Rep Power
    27
    I didnt say i hated the model,i just hate that card!
    The only thing im asking for is just the procedure on how to reset the card to its default(according to previous posts),
    and how to re-write firmware on it once thats done,that is if anyone can send me the relevant documents for the said procedures.
    Is it on the sm and i've overlooked it?
  8. #8
    Service Manager 1,000+ Posts
    Join Date
    Sep 2008
    Location
    Flat Rock Michigan
    1,047
    Rep Power
    49
    Quote Originally Posted by DigiMan View Post
    you should be able to just delete then drag and drop files to it.
    looks as though you have a problem with the field mfp board killing the cf .
    the cards are formatted with vxworks. you can telnet into the controller and issue the command 'vxformat' to fix your wiped card or to convert one from another konica unit to be acceptable to the 601.
  9. #9
    Join Date
    Sep 2008
    Location
    Flat Rock Michigan
    1,047
    Rep Power
    49
    there are base 601 cf files on kmbs in the firmware area.
  10. #10
    DigiMan's Avatar
    Join Date
    Jan 2013
    Location
    In a gadda da vida
    262
    Rep Power
    27
    Quote Originally Posted by Albonline View Post
    Can you kindly provide a link as im not able to find them there and also on infohub which i scoured.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
