Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Service Manager 1,000+ Posts
    bizhub c384e color question
    n25an's Avatar
    Join Date
    Jul 2008
    Location
    miami, florida
    1,030
    Rep Power
    46
    ok... got to a client...
    color is too red...
    after drama... cleaned the idc sensor...
    got rid of the redness...
    ran the stabilization settings...
    but customer said it still did not print things right...
    I am checking if there are any more detail settings and steps to calibrate the colors...
    image looks ok to me... but customer said its off...
    no bluriness...
    just want to calibrate colors...
    spoke with mgr...
    we are going to change the belt and the drums...
    quick side question... whats the best step to clean the transfer belt... will rubbing alcohol work... or is there something else recommended... palm prints on the belt...
    as always any help is appreciated...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  2. #2
    n25an's Avatar
    Join Date
    Jul 2008
    Location
    miami, florida
    1,030
    Rep Power
    46
    Re: bizhub c384e color question
    sorry bizhub c284e
    need sleep...
  3. #3
    Service Manager 5,000+ Posts
    copier tech's Avatar
    Join Date
    Jan 2014
    Location
    London
    7,559
    Rep Power
    182
    Most likely it is their screen that needs calibrating! see this a lot customer not getting printed image the same as whats on their PC screen.
    HOWEVER if you are not using genuine toner/parts you WILL get this issue too.
    No need to clean the belt this won't help.
  4. #4
    habik's Avatar
    Join Date
    Apr 2010
    2,015
    Rep Power
    59
    Try print head skew reset. Then Stabilisation. Gradation. After adjustment ends and you are in main service mode menu press start. (This should be done everytime you do calibrations anyway.)
    Now try Image Background and Stabilisation reset and run fresh Stabilisation and Gradation.
    What's the life of drums and ITB and Devs?
    Sent from my Mi A1 using Tapatalk
    Firmwares HERE
  5. #5
    Join Date
    Apr 2009
    Location
    LaPorte Indiana
    1,054
    Rep Power
    43
    Is it on all print jobs?? What if job is sent from another computer? Just start happening? What is the PM life of consumables? Have you ran the Gradation 3x??
    You can adjust the HUE's and Brightness in the Driver, BUT only after answering other questions.
  6. #6
    RTFM!! 5,000+ Posts allan's Avatar
    Join Date
    Apr 2010
    Location
    Centurion
    5,397
    Rep Power
    152
    Will need a fiery then calibration then more complaints...
    Fixed a call by adjusting a screen when the guy went out of his office for a bit.
    Thanked me for fixing the printer!
    Do as per habik.
    Whatever
  7. #7
    SalesServiceGuy's Avatar
    Join Date
    Dec 2009
    Location
    Nova Scotia
    7,730
    Rep Power
    225
    What app are they printing from? If Adobe PDF, try Advanced, Color Management, "Let Printer Determine colors"
    Does your copier print an internal test chart. If so, print that to determine the copier's baseline for color quality.
  8. #8
    Join Date
    Apr 2010
    Location
    Centurion
    5,397
    Rep Power
    152
    On mac the difference between RGBs and CMYK is night and day.
    Whatever
  9. #9
    Self Employed 1,000+ Posts D_L_P's Avatar
    Join Date
    Oct 2009
    Location
    Canton, Ohio
    1,196
    Rep Power
    53
    For a hand print on tx belt I use a very clean new white rag. Maybe a spray of water on the rag worst case. Just keep rubbing with a dry rag, then run 40 or 50 copies. Seems any cleaner will leave permanent blotches on tx belt. I usex to try alcohol with limited success. Dry rag and many, many copies has worked the best for me.
  10. #10
    Join Date
    Jun 2016
    Location
    Greece
    8
    Rep Power
    0
    Windows or Mac environment?
    file type (raster, vector) that your client "see wrong", RGB or CMYK, if CMYK what profile it was worked with (swop, ISO, fogra etc)?
    i believe there's not much you can do from the copier side (guessing that you have done all the cleaning, graduating adjustments etc), other than installing a fiery
    People will always ask for more without having the slightest clue about color reproduction...you can't get on details about profiling or how environment parameters such as humidity can affect their prints.
    You can't have a basic MFP with the demand of being cheap and accurate...
    In my field I have installed used Fieries on one c360 and one c280, after the clients demanded for more accurate and consistent color, I run monthly calibration with ES-1000, I get paid the visit and everyone is happy...
    I may sound more like a psychotherapist, that a technician, but I have seen that whining countless times.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
