Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Service Manager 1,000+ Posts digicor's Avatar
    Join Date
    Jul 2008
    Location
    tampa Florida
    1,127
    Rep Power
    45
    BH C258 not toning up K
    ive replaced the toner motor assembly,watched the toner bottle turn,
    any idea's
  2. #2
    Master Of The Obvious 10,000+ Posts
    blackcat4866's Avatar
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,471
    Rep Power
    463
    Re: BH C258 not toning up K
    I haven't had those particular hoppers apart, but the 364e hoppers were well know for packing toner into the bushings, so the hopper mechanics would just vibrate, never turning. If it's the same there is a white bushing on the front of each hopper that can be easily removed, then vacuumed out or picking out the chunks. =^..^=
  3. #3
    Service Manager 10,000+ Posts
    Phil B.'s Avatar
    Join Date
    Jul 2016
    Location
    Raleigh NC
    22,792
    Rep Power
    661
    Quote Originally Posted by digicor View Post
    any idea's
    clogged supply lines?
  4. #4
    Join Date
    Jul 2008
    Location
    tampa Florida
    1,127
    Rep Power
    45
    i saw the white bushing, i didnt want to pry it off, not knowing if it was going to break, ill address it and see if that does it, thanks
  5. #5
    Field Supervisor 500+ Posts
    Join Date
    Jan 2009
    Location
    UK
    828
    Rep Power
    50
    I had a c458 today doing this on black.
    It turned out to be the drum.
    I could see a mist of toner on the drum surface which I figured was enough to use up what the hopper was putting in.
    On replacing the drum it rapidly toned up to about 7% and held there afterwards.
    The only thing that bothers me was the fact that the drum was replaced only two days ago so was obviously faulty from new....
  6. #6
    Service Manager 5,000+ Posts tsbservice's Avatar
    Join Date
    May 2007
    7,154
    Rep Power
    346
    any idea's
    There are toner cartridge motor and toner supply motor, which one you replaced?
    Did you check by turning gears manually that developing roller is turning?
    I don't reply to private messages from end users.
  7. #7
    Join Date
    Jul 2008
    Location
    tampa Florida
    1,127
    Rep Power
    45
    i replaced the toner cartridge assembly motor system
  8. #8
    Join Date
    May 2007
    7,154
    Rep Power
    346
    Is this assembly include both motors(M6 and M25)?
  9. #9
    Join Date
    Jul 2008
    Location
    tampa Florida
    1,127
    Rep Power
    45
    it the one in the back of the machine it has all 4 toner bottle motors together as one unit
  10. #10
    Join Date
    May 2007
    7,154
    Rep Power
    346
    Now you have black toner in hopper but it's driven by another motor-toner supply motor, so your toner is only moving half way towards Developer unit.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
