Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 5 of 5
  1. #1
    HilTek
    Guest
    Konica Minolta Di351 network scanning problem
    We took over an office with an old Konica Minolta photocopier recently, a Di351.
    Network printing isn't a problem, but it refuses to scan over the network from any client PC (all of the XP Pro). I tried installing several TWAIN drivers from Konica Minolta but the problem remains: I get an error message saying scanning failed [followed by IP address of the unit]. The Konica Minolta website is downright confusing and there are no clear manuals - one manual states the scanner is equiped with a seperate network interface, which in this case is not (lol). Their callcenter also does not support this model anymore.
    1) How do I get this thing to work to scan over the network?
    2) With scan-to-email you need a POP3 address, is there a workaround if you're using Exchange?
    If anyone has a link to a working TWAIN driver (or a generic one) it's much appreciated!
  2. #2
    Field Supervisor 500+ Posts Scott_Lewis's Avatar
    Join Date
    Mar 2007
    Location
    Great Falls, Montana
    519
    Rep Power
    40
    Just because you can print does not mean it is capable of scanning. You need to have the PS option installed on this model to scan. Can you print to the copier using PS? If you can, then it should be capable of scanning.
    I have never connected this model for scanning. However, the print controller (Pi3502) is very similar to the Pi5501 in the user interface. There are two methods of network scanning that I've used, e-mail and FTP, for this model series.
    From what I can tell, you can only scan to e-mail if the SMTP server is open with no authentication required. This is not the case with any external SMTP servers I've used, lately. The easier method to scan would be to use the FTP option.
    This is a pretty old/simple/basic print controller.
  3. #3
    HilTek
    Guest
    Quote Originally Posted by Scott_Lewis View Post
    I know it's capable of scanning, but that wasn't my question.
    I used the original CD that came with the unit to install PS, also downloaded a copy from the web to install on a different client pc... still the same problem, hence my post here.
    And yes, I can print from any application, PS too.
  4. #4
    Join Date
    Mar 2007
    Location
    519
    Rep Power
    40
    Just answer the questions...........
    Quote Originally Posted by HilTek View Post
    1. Scan to FTP works just fine.
    2. No
    No. Never used TWAIN on this series. Is TWAIN included on the original CDs?
  5. #5
    Service Manager 2,500+ Posts
    Join Date
    Sep 2005
    Location
    South Jersey
    3,837
    Rep Power
    133
    print a config page and see if PS kit is installed with "128" megs ram. this is not loaded with software, the kit is a card that is installed on the print controller along with upgrading the "print controller" ram to 128meg. i have seen scan cards in mach with 64meg ram, you have to have 128meg for scanning to work properly. the ram has nothing to do with your config problem but just wanted to let you know about it.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
