Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 7 of 7
  1. #1
    Trusted Tech 50+ Posts
    Join Date
    Dec 2009
    94
    Rep Power
    30
    konica bh 350 boots to logo screen please wait then to logo screen
    hello everone,
    after changing ip address of machine, it ask to reboot copier, so I did, now it goes to
    that screen, I am going to try to reinstall firmware, can a 4gig compact flash be use
    for this or it must be 128mg. Appreciate any suggestions Thanks in advance
  2. #2
    Join Date
    Jul 2010
    21
    Rep Power
    28
    128MB will be better but have not tried 4G...
  3. #3
    Join Date
    Dec 2009
    94
    Rep Power
    30
    Thank you Steve for your input. I got a hold of the scandisk 128mg and copy just the firmware files to it, but when I tried to boot from the flash card, nothing happens. According to the manual, I shut down the machine with the main switch, I then insert card,
    turn subpower on, then main power. Can someone verify if this is correct. Also does the copier need an old firmware in the machine to update the firmware to a newer version. Thank you
  4. #4
    Senior Tech 100+ Posts
    Join Date
    Jul 2010
    Location
    vizag
    114
    Rep Power
    0
    if u instal firm ware with 128mb cf card ,is it ok.if not u have to instal nvram also.
  5. #5
    Join Date
    Aug 2008
    145
    Rep Power
    0
    if the machine did not start the firmware installation, maybe ur CF card is not compatible (low posibility). i have reflash my Bizhub250 with the step below,
    off the machine, insert the CF card, then switch all the power switch ( main switch and sub-switch) to ON position, then only power On the machine from the power source from the wall plug. this method never fail me.
  6. #6
    Field Supervisor 500+ Posts
    Join Date
    Jan 2009
    Location
    UK
    828
    Rep Power
    50
    Quote Originally Posted by ameritech View Post
    Make sure the cf card is formatted in fat 16 or fat before copying files on to it. The machine will not recognise a card formatted in Fat 32 or ntfs...
  7. #7
    Senior Tech 250+ Posts
    Join Date
    Jan 2010
    Location
    Sydney
    378
    Rep Power
    32
    hello everone,
    format your CF card using KM Firmware Imaging toolkit.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
