Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Marcohey
    Guest
    Post Problem with Fiery 50c-k Bizhub pro c500
    I am having printing problems from my pc on c500. Copies are ok. I reinstalled software for fiery but still same problem.
    Anyone has seen this issue before? attached scanned printing results.
    Any help will be welcome
    PruebaImpres01.pdfPruebaImpres02.pdfPruebaImpres03.pdf
  2. #2
    Senior Tech 100+ Posts
    Join Date
    Feb 2011
    Location
    Brasov
    229
    Rep Power
    29
    Re: Problem with Fiery 50c-k Bizhub pro c500
    Never had this, but it looks like a poor contact to me. I will encourage you to call a tech, though. Good luck!
    I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?
  3. #3
    Field Supervisor 1,000+ Posts
    TheOwl's Avatar
    Join Date
    Nov 2008
    1,734
    Rep Power
    62
    I'm going to go out on a limb here and say that it could be the RAM.
    You have done the right thing and re-installed the OS, but the pattern on the prints looks like noise or corruption. When I looked at the print jobs, I noticed that the smaller jobs only had the lines in one area, but the last file had them across the entire page. Was the second file bigger than the Windows test page?
    The reason I ask this is because you might have a bad address within the RAM and you are only writing to the bad address once a print job reached a certain file size. This is my reasoning to believe that it is the RAM.
  4. #4
    Marcohey
    Guest
    I Did it, but tech is not able to find the problem
  5. #5
    Marcohey
    Guest
    Quote Originally Posted by TheOwl View Post
    We Checked the ram and it looks it's ok. the second file it was a text wrote on office, small size.
  6. #6
    TheOwl's Avatar
    Join Date
    Nov 2008
    1,734
    Rep Power
    62
    What about the RAM in the copier?
  7. #7
    Marcohey
    Guest
    RAM in copier is ok too, we changed RAM and results are the same, even printing from another computer. I am thinking problem could reside in the flash ROM with corrupted data in any of the boards. maybe reinstalling with ISWTrns with fresh data could solve the problem, but I do not know where to get it.
    • Overall control board (OACB)• Printer controller board (PRCB)
    • Operation board/1 (OB1)
    • RADF control board (DFCB)
    Sometimes printing looks like this scan all black lines (Test.pdf) but if i change orientation from A4R to A4 black lines dissapear but still appear a bar on bottom
    Test1.pdf
    Test.pdf
  8. #8
    Field Service Manager 1,000+ Posts
    pepper38_cnd's Avatar
    Join Date
    Aug 2005
    Location
    Windsor, ON Canada
    1,075
    Rep Power
    51
    What Controler do you have ? Is it an IP921? If so take a look at this and see what you think
    Attached Files Attached Files
    Now into Ip TV KODI Boxes
  9. #9
    Gimp 500+ Posts JSC's Avatar
    Join Date
    Dec 2006
    Location
    Devon
    618
    Rep Power
    46
    if the machine has been ruled out of the problem,try changing the cable from the Fiery to the copier, if no change i'd be looking to replace the video interface card.
    The gene pool could use a little chlorine.
  10. #10
    Marcohey
    Guest
    Quote Originally Posted by pepper38_cnd View Post
    Yes, it is an IP921v 1.1 Make sense trying installing that pacht. where I can get it?
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
