Results 1 to 7 of 7
  1. #1
    Join Date
    Nov 2014
    Location
    Atlanta, GA
    24
    Rep Power
    20
    Question Copystar CS520i Error Code C2250
    during copying the user called and they have a error code C2250.
    I pulled the charge assembly and it appeared jammed I think the gear was off a little, I reassembled it and then the wire cleaner was able to travel without binding .
    I reassembled the copier and ran the hard reset.
    after a few minutes the error code C2250 Reappeared. any suggestions please?
    I don't like to guess, and I'm a bit rusty getting back in to the service business
    Thank you in advance.
  2. #2
    Service Manager 10,000+ Posts
    Phil B.'s Avatar
    Join Date
    Jul 2016
    Location
    Raleigh NC
    22,790
    Rep Power
    661
    Re: Copystar CS520i Error Code C2250
    Quote Originally Posted by Raydicks View Post
    inspect the drive for the charge unit... make sure that gearing is good.. if fine replace charge assy
  3. #3
    Join Date
    Nov 2014
    Location
    Atlanta, GA
    24
    Rep Power
    20
    Thank you for the advice!
    I assume that is the motor assembly with the smaller motor inside ( see attached photo) correct? do you know what the drive voltage is for the motor?
    and can the drive assembly be replaced without the entire Main charge unit MC-710 and I am pretty sure the part # for that whole assembly is 302GR93071 or 2GR93071? Thank you for your assistance I"ll let you know if it works.
    I had taken it apart yesterday and it appeared ok but it was locked up after disassembling it and reassembling it then it worked. I reinstalled it and reset the copier and then i got the same error code after it tried a few times.
    Thank everyone for reviewing and Phil B for the advice! I'll check today
    Attached Images Attached Images
  4. #4
    Phil B.'s Avatar
    Join Date
    Jul 2016
    Location
    Raleigh NC
    22,790
    Rep Power
    661
    hey Brother.. hope it werks out for ya!
  5. #5
    Field Supervisor 500+ Posts
    Join Date
    Oct 2010
    816
    Rep Power
    45
    We found that in the long run just replacing the whole unit was cheaper than making 3 or 4 trips to try to isolate it to the motor or the charger itself. It never failed that whichever part we replaced first, it would turn out to need the other instead. Replacing the whole unit always got the job done in one.
  6. #6
    Senior Tech 100+ Posts daveh12's Avatar
    Join Date
    Jul 2012
    157
    Rep Power
    25
    You can clean the charge wires very easily manual then just leave the motor unplugged. It's only for the charger auto clean. Will work fine without
  7. #7
    Join Date
    Nov 2014
    Location
    Atlanta, GA
    24
    Rep Power
    20
    Re: Copystar CS520i Error Code C2250 has reappeared
    Thanks for all the ideas and advice.
    I did replace the complete unit. and everything worked great for about 4 months then today the same code happened.
    I don't know if it matters but the user was wanting to fax something but it was in copy mode . entered the phone number and hit start it started copying over 1000 pages and then this error came up again.
    I've reset power and checked the connection any suggestions?
    Thanks...
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
