Thanks Thanks:  0
Dislikes Dislikes:  0
Results 1 to 7 of 7
  1. #1
    kataria2013
    Guest
    Kyocera 5050 Error (C7900)
    Km 5050 displays C7900. I have changed everything like new drum unit, new boards (engine and main) , checked the wiring section but still the problem is not solved. Im fed up of this problem if someone knows plz help
    Sent from my ONEPLUS A3003 using Tapatalk
  2. #2
    Service Manager 10,000+ Posts
    Phil B.'s Avatar
    Join Date
    Jul 2016
    Location
    Raleigh NC
    22,792
    Rep Power
    661
    Re: Kyocera 5050 Error (C7900)
    Quote Originally Posted by kataria2013 View Post
    what does the manual say is the issue?
  3. #3
    kataria2013
    Guest
    C7900 Drum unit EEPROM error Reading from or writing to EEPROM cannot be performed.Remarks : Check the connection of connector on the engine PWB and the continuity across the connector terminals. Repair or replace if if necessary. Replace the drum unit. Causes :
  4. #4
    Phil B.'s Avatar
    Join Date
    Jul 2016
    Location
    Raleigh NC
    22,792
    Rep Power
    661
    Km 5050 displays C7900. Im fed up of this problem if someone knows plz help
    welcome to the tech world.
  5. #5
    kataria2013
    Guest
    Sir is there any solution to this?
  6. #6
    Master Of The Obvious 10,000+ Posts
    blackcat4866's Avatar
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,471
    Rep Power
    463
    Have you changed the drum unit? That's the only cause I've ever seen. If that didn't do it, then the engine PWB. =^..^=
  7. #7
    Field Supervisor 500+ Posts Geo's Avatar
    Join Date
    Nov 2010
    661
    Rep Power
    38
    You may be using the wrong drum unit. If memory servers me correctly the 4050/5050 takes a DK 716. The 3050 takes a ( DK 715) and it will fit but throw a code . This was a common mistake.
    Good luck.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
