Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: 5501i series?
  1. #1
    Senior Tech 250+ Posts
    5501i series?
    copydocinc's Avatar
    Join Date
    Mar 2015
    Location
    Bountiful, Utah
    256
    Rep Power
    22
    5501i series?
    My company is not a Kyocera authorized dealer, but have been involved with Kyocera machines as a 3rd party service company for many years now.
    We also have many tech certifications on Kyocera's, but dating back to Falcon I series.
    For quite a few years we have been rebuilding and selling the Falcon I, II, III series (KM2530,3530,4030)(KM3050,4050,5050)(TA420im520i)
    It looks like it may be time to start rebuilding and selling the newer Taskalpha 3501i , 4501i, 5501i
    These models are built and look different than the Falcons.
    My question to you Kyocera experts is are these machines as reliable or better or worse than the models we have been selling?
    Will I be running into a lot of problems?
    What do you think?
  2. #2
    Field Supervisor 500+ Posts
    Join Date
    Sep 2008
    Location
    Texarkana, TX
    646
    Rep Power
    38
    Re: 5501i series?
    ours are located in schools, they will run pm to pm. the only issue i have seen is the charge rollers getting paper rings on them and causing black lines, but if i remember correctly, there is a new part number that has a better cleaner. we clean them with water/alcohol and they run fine.
  3. #3
    Join Date
    Mar 2017
    13
    Rep Power
    15
    Re: 5501i series?
    They run pretty well on genuine toner, I look after in excess of 100 of these machines and have vey little problems.
  4. #4
    Master Of The Obvious 10,000+ Posts
    5501i series?
    blackcat4866's Avatar
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,471
    Rep Power
    463
    Re: 5501i series?
    They do tend to blow toner. I would include a good internal laser cleaning in my refurb. =^..^=
  5. #5
    Service Manager 1,000+ Posts
    5501i series?
    Join Date
    Feb 2010
    1,989
    Rep Power
    75
    Re: 5501i series?
    The Falcons, are in my opinion, the finest copiers ever made but those days are long gone. When we refurbed Falcons it was one PM kit. A single tech could strip it to the frames and do 4 a day.
    You won't see the same return on the dollar. The drums are rock solid, but that's about it. The fuser wear quick and make noises, the clutches fail and yes they run dirty.
    The charge rollers have been updated very recently so hopefully those issues are behind us.
  6. #6
    Senior Tech 100+ Posts The_Murph's Avatar
    Join Date
    Mar 2016
    Location
    Erie, CO
    96
    Rep Power
    17
    Re: 5501i series?
    Quote Originally Posted by JR2ALTA View Post
    They've updated the Drums and Charge rollers to the same style as the XXX2 models. If you are going to replace MC's I would go ahead and replace the Drum unit, it will provide more stability and reliability in the long run.
    If you phrase your inquiry properly, you will get the answers you seek...
    Good Luck ... You'll need it! HAHAHA!
    ~Big Dan~
  7. #7
    Service Manager 10,000+ Posts
    5501i series?
    Phil B.'s Avatar
    Join Date
    Jul 2016
    Location
    Raleigh NC
    22,792
    Rep Power
    661
    Re: 5501i series?
    Quote Originally Posted by LNorris View Post
    i have had GREAT success using "Nu Finish" car polish on charge rollers.. ( everything from Canon - HP - Oki - Xerox - Samsung - Muritec - LexMark - Ricoh ) clean with water.. dry.. coat roller with the polish and buff off... ones with really bad build up.. repeat. Tends to keep build up off and makes the print bolder.
    I have also used " Rain-X " on copier mirrors that tend to build up ozone quick.... alcohol first then the rainx
  8. #8
    Join Date
    Oct 2016
    Location
    Dover, DE
    15
    Rep Power
    0
    Re: 5501i series?
    I just Googled Rain-X , it is a Car cover ???
    I am sure this is not what you are using . Can you please give us more details about that .
    Thank you so much in advance
  9. #9
    5501i series?
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,471
    Rep Power
    463
    Re: 5501i series?
    I think this is what he means:
    https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
  10. #10
    Join Date
    Oct 2016
    Location
    Dover, DE
    15
    Rep Power
    0
    Re: 5501i series?
    Tank you blackcat4866
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
